Loydd,
I replaced the entire clutch set up. Adjusted the slave and the clutch when it was cold.
The clutch disc. sperates fine. Goes into all gears smooth except for reverse. Grinds when trying to go into reverse.
I have to turn the motor off, put it into reverse and then restart the motor with the clutch in. Car does'nt move at this point until I let out the clutch and then reverse works fine. Going from reverse to 1st is no problem after that.
Any suggestions ?
Thanks.
Coz
[This message has been edited by Coz (edited 12-14-2001).]
