this is an attempt to run ac in the arizona heat.
after 30 minutes at idle in a 103 degree garage with the ac on, the cooler removes 8000 btus, the PWM controlled  Spal Fans never ramped up as it maintains the oil temp.
before the car would over heat at 90 degree outside time in city traffic witt the ac on, i still have some things to button up before i take it for a test drive.
if you want to order one from  Ron Davis, i would make the core 18” left to right and i would fill the corners of the flange in so it rests on weather stripping
This one is 20” long, something got lost in translation which happens on one off parts.IMG_1902IMG_1900IMG_1896IMG_1897
Images (4)
  • IMG_1902
  • IMG_1900
  • IMG_1896
  • IMG_1897
Very cool!
This is an air to oil cooler? You’re bringing in air through the vent on the back of the car?
Where do you pick off the pressurized feed of oil to the cooler?
And so it must add to oil capacity?
It seems like the top of your oil cooler is much higher than the level of the oil in the sump.  How do you keep it from draining back and overfilling the sump when the engine is shut off?
Looks like a very clean install!
That is a really nice set up.
To my knowledge, and not posted as a criticism at all, just a different solution that others may not be aware of, the factory Gp 4 race cars used an oil cooler mounted to the right rear inner fender dust shield.
They used the natural air pressure created by the revolving right rear tire as a circulation fan to draw air through the cooler radiator.
That is where mine is located. What I did was have a louvered cover made for the dust shield, fabricated a stainless steel sheet metal dust shield and mounted the cover and the cooler "radiator" to it".
In addition I mounted a oil temperature controlled switch to turn on the fan at 210°F. I ran -10 braided hoses from the original oil filter location to a dual filter remote adapter and then to the oil cooler.
That set up along with the Aviad oil pan puts 12 quarts in the system.
So far so good but for my use the fan over the oil cooler radiator seems like overkill since I don't drive the car hard enough.
I point this all out here since maybe driving in the summer Arizona heat might make this all more useful?
There is also a remote oil temp thermostat installed in line since you want to minimize over cooling of the oil and want it to heat up to a certain temp.
That thermostat is set at 200°f.
Here is a picture of the sheet metal louvered cover. One of the "street rodders" stamped this one for me. He has one of those monster louver stamping machines that can do hoods and fenders. It's good to stay on friendly terms with those guys.
Locating the oil cooler there utilizes otherwise useless space, provides good access to that assembly, and leaves my a/c location alone in the back.
Just my usual, "beat of a different drummer" attitude I suppose? Sometimes that's a good thing. People sometimes just stare, open mouthed, and walk away without asking questions and I'm not even armed!
I sometimes think that I see concern on their faces?
  • LOUVRED PANEL 2
I’ve seen them mounted there, since i’m in AZ one of the first mods i’ve done is moving the condenser to the front.
i have a Vaccum pump for the brakes located where your cooler is.
ill adjust the PWM fan control cut in at a higher temp if it continues to run at below 180 degrees.
gonna take it down the road with the temp clamps and  air temps sensors.
i have 6’ extension cables for the k sensors so ill route them in the car.
Just looking to run ac in the arizona heat, i’d like it to be drivable all year round out here
@Bell3156 posted:
AZ is a different Universe then the one in NY, in so many ways.
I can only share what I did in offering ideas for you. You are the best judge of what needs to be done for your conditions.
It is interesting though that the Pantera is flexible enough to accommodate these changes without too much drama?
Maybe that has kept the boredom away from me for all of these years? It isn't like it doesn't have it's own criticisms against it?
Nice setup.
This is the first year I've run my car in the AZ heat.  So far so good, no overheating and AC works well enough, could always be cooler.  Getting ~53F at the vents now and I'm certain it's a quarter to half pound low on R134.
I'm using Ron Davis radiator with SPA fans, AC condenser in the stock location.  Based on cabin temperatures only, I can't tell if the AC is better with or without the rear trunk in place.
Coolant temps range from ~190 to 210F when sitting in traffic with AC on and 113F ambient temps.
John
#3590
forgot to mention I'm running the header tank modification, flow Kooler pump and Robert Shaw 180 Thermostat with bypass plate.  engine is a mild build with Aluminum 3V Heads and intake combo, Isky cam, etc.  Maybe 450HP at best.
I can't prove it since I never ran the car with the original swirl tanks, but I believe the header tank conversion makes a big difference.
I am using the Compcams vac pump. I have it mounted on the top of the chassis v brace behind the A/C compressor.
You can quiet it down by putting a muffler/noise silencer on the intake.
There is a lot going on in that area on my car but it is all accessible from underneath.
As stated, that is where my oil cooler radiator is mounted.
any chance the timing is off slightly?  Is it slow to crank once hot?
I've learned on this forum that if it isn't boiling over then it isn't really overheating. I do watch my gauge constantly but have learned that it may not be 100% accurate especially when the temp is increasing quickly.  I have the diode mod on my temp gauge as well and pretty sure the rate of temp change isn't accurate.
I had to experiment with my header tank coolant levels to figure out the right coolant levels.  Too much coolant and it will puke out with the air bleeding off.  Seems like about 6" from the top of the radiator cap is where mine is happiest.
For reference my Raptor will run about 230F on the freeway if I'm pushing it up to 80-85MPH.  If I back off, then it drops back down into the 220F range.  I know this isn't an apples-to-apples comparison but a good idea on temp.
