Sorry- 0.022" divided by 2 (since the disc works on both its surfaces), means only 0.011" of friction-surface separation. You will have massive drag on the gear synchronizers, I'm afraid. Either the multiple steel-on-steel contact points in the clutch linkage is badly worn, especially in an 'L' model with the over-center mechanism under the dash. the needle bearings on the bellhousing cross-shaft or the adjustment on the slave cylinder is not correct. For loose under-dash linkage, the only fix is to remove it, weld up the holes & re-ream to size plus replacing the worn shafts. This means pulling the dash as theres no access otherwise. OR, it may mean internal leakage in the master cylinder and/or slave. You can install a long-throw slave, in stainless steel, and I suggest a new ss clutch master as well. Believe me, the car will shift better, and its an investment in NOT spending thousands for a ZF overhaul later.
