Comming back from an hour trip, came to stop and when I proceeded to go, strange vibration..especially after more RPMs. thought it might be a flat tire...Nothing loose, plugs and wires look ok. but when I rev it up, vibration increases, even sitting still. could it be the Timing? sounds like a dull vibration comming from engine.
I have had this car for 10 yrs, never heard this before. but whats new with a Pantera..
If it's the original motor, I'd check the harmonic balancer. It consists of two pieces(inner and outer)with volcanized rubber attaching them together. Over time the rubber lets go and usually just slips, but sometimes the outer piece will let go and could cause major damage.
I am thinking ignition problems....maybe fouled plug or bad wire. take a look under the dist cap....... One thing you can do is remove one plug wire at a time while the car is running. If you remove one and it does not change the idle..then that may be the failed cylender. You may want to wear a thick glove that is shock prof, because the voltage is quite high, anyway if it shocks you youll know the fire is getting there.
I haven't had time to get at the engine yet. checked wires and plugs. all seem ok. Had to go away on business for 4 days. Hoping it is just the Balancer, replace that so I can use it for the summer. Then I want to pull the engine, and have it rebuilt. only 47,000 miles on it. runs strong
replace gas tank, had 1 leak. Still love it though.
I don't know if this could be your problem... Maybe the motor mounts have given up over time and have cause the exhaust to hit the chassis somewhere. I'm assuming that this vibration occurs when the car is stationary and or going down the road. The only two things come to mind would be exhaust or balancer. Keep us updated
While engine running, pulled off plug wire 8, no change in engine, put back, tried 7, same. tried #5, same. pulled out Pcv, no change. It still sounds to me like timing is off. or detonation is not right. I'm just a weekend Mechanic, so it may take me some time. but I don't give up easly.
AttaBoy, karlc, Do'nt let 'em get you! Tell us a bit more about your ignition...MSD? What distributor? My car gave me fits with poping and skipping, I changed everything,wires cap, nothing helped UNTIL I replaced the plugs and gapped them at .050 for the MSD box, and it has not missed a lick yet. Once a plug gets wet fouled, they should be replaced. I would at least pull a couple and look at them. A mis will cause a vibration.
KARLC,
2 things come to mind that you can check ??
1. The balancer ..take the engine cover off and inpsect it... is the rubber in the middle of the outer ring there ?? does it look like the outer ring has rotated ??
2. take off the valve covers and see if all the keepers on the valves are there and the valve stem potrudes about a 1/4" above the keeper ... any broken valve springs ??? LOOK CLOSE.
3. this is a long shot .. but I purchased 2 cars .. and both have similarities. I bought a 68 427 corvette that had a 454 flywheel on it and a 66 428 cj that had a 427 flywheel on it. Both were mix matched with internal and external flywheel balancing.
how did I get the same problem twice in my life ?? LOL
Ron
Ron
Troubleshooting like this is very very frustrating. However, if removing a spark plug wire from 3 different cylinders did not make the engine run slower & rougher, that is significant.
Something is amiss. I reason if the timing had slipped, the motor wouldn't run at all, or would buck very badly. So I'm guessing the spark is very weak.
If it were me, my next step would be to check the voltage to the ignition system with the engine running, pull a plug and inspect the electrode (I would expect to find a black & wet plug)and finally run the engine with a plug removed and grounded so I could see the spark (it should be fat & blue).
your friend on the DTBB
yeah Ron, it would run & vibrate. BUT Karl pulled plug wires off with no drop in engine speed or rougher idle. If this is so, the motor is running pretty poorly. The motor will maintain its state of tune if the balancer spins, it will just be out of balance, and yes in that circumstance it will omit a hum, I've heard it before. but what we have here is a motor running so poorly that pulling a plug wire makes no difference. If it were a slipped timing chain, it wouldn't run at all. So what does that leave us?
What we know is the problem occured during a long drive, it was running ok at the beginning of the drive, but was "vibrating" at the end of the drive. No changes had been made to the motor.
come on guys, whadda ya think?
  • mechanic___02
THanks Guys. I checked the Harmonic Balancer, looks good. rubber intact, Timing around 13 TDC I replaced the plugs Used Autolite AP25, gap 35. I have a Ford Electronic ignition system that I purchased from Hall Pantera about 8 yrs ago. came with Module, distributer coil etc. Car has plenty of power, if I get into it, it goes no hesitation. no skips. engine mounts are ok. Noise seems loudest in 1st, 2nd & 3rd gears, around 22-2400 rpms. mostly in 2nd gear. had car out for 1/2 hour, 65 mph in 5th. smooth and clean. but I do hear something in background.
Just a hunch, but have you been to Disneyland lately?
Many times that humming sound is just in your head. It comes whenever you take the "It's A Small World" ride. That song is almost impossible to get it out off your head and many times people hum it unconsciously, thinking the resultant sound is coming from the engine, computer, toaster oven, whatever. The good news is, I don't believe it has ever damaged a Cleveland engine.
BTW, this hum is not to be confused with Dynamo Hum. That's a totally different hum.
Whadda ya think?
Jeff
6559
OK Karl....
If the noise/vibration is only heard/felt when the car is moving, you'll need to foucus on the parts that only rotate when the car is moving such as wheel bearings, half shafts, squirrel cage, etc.
But that still doesn't explain why removing a plug wire didn't affect the motor.
Its a small world after all ........
Noise is there standing still or moving. around 22-2400 rpms, especially in 2nd gear. George, I
pulled plug from #8, started car, grounded plug. I see a white jagged spark, not blue or fat. Car runs smooth, no noticable noise in 4th or 5th. no skips, and it flys if I get into it in 1st gear.
I didn't hear any difference when I pull the plug wire, but I didn't look at tach. will make sure tonight. Hot as hell out here 98 yesterday.
Maybe the Coil has gone bad!!
