Dave I moved your Post to it's own Topic, I hope that doesn't create any confusion...George
quote:If it were my choice, I would make the Hilborn set up my first consideration.
quote:Originally posted by george pence:
Regarding the Redline manifold, I considered it & shrugged it off. My reason for doing so was because the rear of the manifold would have to be modified to mate with the Windsor block, and you are still left with having to use a thermostat housing adapter. I figured a machined Windsor manifold would result in an end product better matched to the application. If it were my choice, I would make the Hilborn set up my first consideration.
your friend on the DTBB
quote:Originally posted by accobra:
George,
The Hillborn set up appears to be a 3 piece manifold ?? 2 intake runners one for each side and a top plate to cover the lifter valley ? I also have been inquiring about mounting throttle bodies on my weber manifold and employing EFI injectors into each runner. The only difficulty is the throttle bodies to mount on the webbers intake. The rest is all made for teh windsor.
Ron
quote:Originally posted by #5972:
I forgot about Dennis' system, and I believe it can be had in a configuration that fits under the engine cover/deck lid.
quote:Originally posted by DeTom:
Also you guys should be aware that Weber does make an EFI that looks just exactly like it's carbs. Hilborn also make full mechanical fuel injection systems for the Cleveland that you don't have to have NO computer for. You just need to fiddle with it like you do the Webbers and it will never be tame on street machines. So if you are real old school and hate new fangled computer crap, like me, you can get the good old mechanical system brand spanking new out of the box. If I had half the money I would get that, but it is more just a pipe dream for guys like me. Hilborns and bundle of snakes. What else could anyone want????
quote:Detom. That is the drawback to EFI. It takes tallent to hide the wires!
Doug my buddy. These are right up your alley. Check it out. You can have fuel injection without computer crap!!!
http://www.hilborninjection.com/category.asp?Id=99
