It's only the angle. I got apr. 3" of clarence..
Door done. Now clearcoat.
Getting there.
Now the funs begin. Putting on the little bits, as markers and so on
I really like the color. Look forward to seeing some pics when its all back together.
Blaine
Blaine
I liked orange, but now I like Lambo Blue!! Very very nice!
Looking GREAT!!
Ron
Ron
Very nice choice. Looking great. Keep the pics coming.
Kelly
Kelly
Puttting on the NEW rear lenses and the cleaned logos makes so much for the looks. Cant have shabby parts on the new paint.
Next item to put on the car. Delivered to UPS today. A good old Hall 180.
Looks nice and I love the sound at 5500 rpms! Be sure you put up a decklid heat-shield on stand-off mounts before running them hard. It's possible to CHAR paint in two spots on the decklid about a foot in dia on each side, from the heat coming off those pipes!
Looking great! What an awesome car
I've got those headers too.(a later version) I think that the only solution to them is to get then cermacoated. This way it is possible to run a modified trunk liner without it catching fire!
...ask me how I know!
Something says me that your trunk got a bit TOO hot?
How can you tell?
If you are running a little lean those headers will glow red?
Started work on the bracket to hold the silencers.
I'm not sure if I'm satisfied with this piece that holds the clamp. Will finnish it up and see. Will at least weld shut the hole in the back.
Decided it was good enough, and polished it. Now, it seems like I will need to polish a few more items in the enginecompartment to match this piece.
Started work on another piece my car really don't need, but I want..
Pic from my mobil, so not to good.
Nice... really Nice,
Enjoy the build, it looks great... sorry about the idiot who damaged the new paint. The blue is a great color.
A good color is so hard to find, I went crazy finding the right yellow for mine. I wound up with 7 coats of "Smart" car and 4 coats of gold pearl 3 coats clear. Best of luck and again it looks great.
Joe 6656
Joe 6656
Recived my new valve-covers today:
Some new tires to try out next summer:
Front:
Seems like I need a extra pair of rims now in 8 + 12 x 18".....
Testing of how far in I want my two-barrel shotgun.
trying out an idea for the area around the exhaust. Not the final finish of course, since I have just mocked up the parts to see if it turns out like I want.
Another wiew.
where did you get the carbon fiber exhaust cover/trim? what are your plans for the old exhaust body cutouts? maybe carbon fiber
If you think about the panel around the dampers, I made it myself (a sandwich construction to be stiff) that bolts to the holes the original mesh used. The cutouts, I dont know about yet. Will need to think about that for a while.
Are those motorcycle mufflers?
No. They are typical dampers used by the Supra-tuner-drifter-guys. It has a detachable insert that gives it allmost free flow when no silencing is needed..
Started work on some side scoops. Plan not to loose all the visibility you do with the carbon type, so they will be made in lexan, and have attachment for a 4" hose to rout the air. Will have an opening of 2". This is just a test, and the plug will be made much nicer to get good looking parts. As you can see in the red sircle further down, all imperfections in the plug show after vacum is applied.
Scoop. Still no opening, but you get it.
Rear pice.
Together..
Mock up of scoop on car. Dirty parts give much bad reflections, but in reality it looks quite good, and doest stand out as much as a colored piece will.
sideview. Should have cleaned of the window and scoop first.
Sideview. Should have cleaned the parts befor I took the photos..
quote:Started work on some side scoops.
How did you make those lexan side scoops. Beautiful work! Also, what are you pointing out with the red circle in the picture with the scoops together?
