Hello all,looking for some help.I just installed a demon 650 double pumper on my pantera and need some advice.The car had a big Holly on it when I bought it but an engine fire had ruined the carb. It had a funky homemade adapter to connect the pantera cable to the Holley throttle.This adapter does not fit the demon correctly. No matter how I hook it up I can't get more than 3/4 throttle opening because of the short pull of the pantera cable.Has anyone run into this problem?Is there a company that sells a workable solution?Has anyone made an adapter,linkage,throttle thing that I can copy?Any help or Ideas would be appreciated. Thanks
