OK, bear with me this may be so simple that I don't see the solution (again!) I replaced my carburetor and now my throttle cable is too long by about an inch. Both end screws are taken in as much as possible. I've thought about modifying the connection to the carb but thought I'd check if there was another way to take up the slack that I've overlooked. Any ideas? Thanks in advance!
