Long shot I know, but does anyone have, or know of one? Did they feature on any other cars? The one currently fitted looks like it came from a Meccano set! Delivery to the UK is needed.
Fan blade was shared with Maserati QP series 1 , as used for the small white fan at the radiator. I took forever to find that...the bracket itself is all-thread. The fan motor may have come from more than one source, but as I can tell 8ma1046 used a Motorcraft dual blower fan motor with the rear shaft cut short (exposing the shaft end). 8ma1074 used a different motor.
