Good evening,
I just finished the Wilwood SACC brake upgrade as well as added the Wilwood MC and proportioning valve.
Just curious if anyone has installed the Wilwood MC and if they used the .250" nylon spacers in kit? I talked to Scott at SACC and he said no one has mentioned any issues. I'm not having an issue but there are only 1-2 threads engaged when using the spacers. Wilwood says to use the spacers, but this isn't a Pantera only MC so looking for advice.
My thought is that the spacer will limit the plunger travel in the MC bore but maybe I'm wrong about that?
The brakes are working but just seems odd to only have 1-2 threads of engagement.
Thanks,
John
#2551
