Likely in all of the original applications of these EPS units, they plug into the original CPU in the vehicle to get their VSS information?
The CPU supplies the information of how much boost to provide and since all of those vehicles use their own VSS units, if you want to apply one like we are doing here, to the Pantera, without a Yaris, Toyota, GM or even a Misubishi CPU, then I think it is necessary to have some sort of a boost control?
Understand that initially, none of us knew if the EPS would work at all without the original vehicles CPU?
In retrospect, it appears that used in conjunction with the seperate original "add on control box", in leu of a VSS signal from the original vehical CPU from it's own seperate VSS, the EPS will function on full boost all of the time rather then the opposite, of not functioning with any boost at all without a VSS signal?
Bruno is the source of the adapter that substitutes for the CPU's, as previously stated, and if "he don't know, then nobody does". If your Mitsubishi unit is working now without any sort of VSS assist, then you probably don't need an add on at all. It is just on full boost all of the time?
There is another EPS unit that the ATV people are using. It has it's own CPU device and the steering unit itself is actually a little bigger then the Yaris, but the point is, there is more that works then the Yaris but few if any are the size of the Yaris.
It isn't a cheap set up. So initially when doing a feasibility study without "Government Funding" sources, I explored possibilities and finally discovered the Yaris RHD.
In the Pantera, that small size  is paramount and MAYBE the most important factor?
Thanks Doug.
And that’s the case that my unit is always on and it’s good until 45mph but not beyond and hence I need a controller.
However a GPS velocity controller is only good until you have a signal. There are many situations where you don’t have a signal anymore. I will explore from EZ EPS from the Netherland their speedometer cable sensor. This devise is more reliable in that sense.
@FWJ posted:
Thanks Doug.
I would advise that you read the item description on Bruno's web site on how the GPS unit works.
You also have the option of using his first controller developed that is manually controlled.
I suppose it all comes down to where you are primarily driving? In the US, it isn't that significant that you dial down the boost since we do not have Euro Autoban unlimited speed scenarios?
Inquire with Bruno. I suspect that your Mitsubishi is a variant of the Toyota technology and even if that doesn't matter, it may be Bruno that has the Interphase VSS that you are searching for to begin with?
He is the go to guy on this subject.
