Posted February 22, 2007 10:07 AM Hide Post
thanks , i cant seem to find the power for the blower is it a red cable per the diagram? I have a yellow one that goes to a coil thing beside the evaporator box and a brown with a blue and black and white and black cablethat i dont know where they go too!
That coil thing is a ceramic resistor that is the method by which you get two speeds.
Power hits the console switch. In low, power leaves the switch and hits one end of the resistor, passing through the coils and losing voltage in the process. The other end of the coil should then go to the motor power input. Motor needs ground input from the chassis.
In high speed, power leaves switch on another wire and instead of passing through the resistor, goes directly to the end of the resistor and thus to the motor. Your colors may not match the diagram, because when Guido or Luigi ran out of one color, or if they had too much vino during lunch, the colors really didn't concern them that much. They wired it to work and that was that.
Follow the wiring, not the colors and you should figure it out.
By the way, are you the seller in PR that was selling parts on eBay?
