Hi all,
I'm building a new trunk insert THAT WILL NOT RUB THE PAINT on finished engine compartment cars. It has raised fastener areas that set on the pad and has totally been re-designed making sure it will not touch anywhere inside. The AC condenser area is larger for better air flow and to use a larger condenser and fan system. The spare tire cavity will be eliminated and the new design will be symmetrical side to side. The floor has two separate hidden compartments about 5'' thick---one for a tool kit (which will fit the factory tool pouch) and another for rags, polish, detail items and/or self preservations needs. (beer, pistola or a small P90 size PSD) The floor is flat when the doors are down and everything under is out of site leaving enough storage for an overnight bag, folding chairs, small cooler, wife or friend stuff.
I have wanted to do this for many years but now have a real need for several in-house car under construction. The first design will be made to fit 9000 serial number cars and up so if you have a late model hand-built wheelhouse car and would like a trunk that will not rub damage your engine compartment, please drop me a note. Sorry---not finished yet so I do not have the costs yet.
The first early production car version (1971 through vin 8999) should be available late Winter-early Spring.
Thanks
Kirk
