I went to drive my new (to me) Pantera, and discovered the blinkers, and the tail lights that should accompany the headlights are not functioning.
Tomorrow I intend to troubleshoot the normal things, check voltages, check bulbs, chexk fuses, but I was wondering if anyone knew whether the taillights and blinkers were on the same circuit/fuse?
I know some comapnies/cars had certain circuits combined so you'd notice if there was an issue more quickly.
Tomorrow, again, I plan to troubleshoot the wiring, I just want to limit the number of times I arm the ignition/fuel pump without actually starting the car (car has EFI with ITB's).
I'm not sure if every time I turn the key to "on" that it shoots some fule into the engine for starting, so it would help to know if the blinkers and taillights were on the same fuse/circuit.
I'm on my 3rd day of ownership, still learning about the car.
Any help would be greatly appreciated.
