After a total restoration of my brakes and booster I did not notice any check valve in the brake vacuum line. This would account for a dramatic loss of brakes when the car stalls and braking is required. The parts manual does not show one. Is there an in line valve or should the banjo fitting that connects the vacuum line to the booster be one way? Thanks Mike
Hi Dick,
Thanks for that. It makes sense as the car I am working on has webers and no valve that I could find. I will look on the original manifold that I have to see if it is still there. Knowing that they originally came with a fitting makes sense as these cars would have little assisted braking whenever the throttle was wide open.
Thanks Mike
where can I buy onre of those valve's?
I need one for my Longchamp.
Simon
Mystery solved. The Pantera has a check valve in the banjo fitting that goes directly onto the booster. I took off the hose from the hard line under the front area and the vacuum side I could hear a "valve type" noise and when blowing the valve closes and holds pressure. As to where to find one for your Lonchamp I would try the usual US vendors as it is probably the same if it has a Benaldi Booster.
