I'm trying to figure out how and exactly where the decklid struts mount, especially on the bottom. I have a couple of pieces of angle iron bolted to the wheel well panel but these are obviously incorrect. The new struts want to wrap the decklid. Picures of other cars seem to show the bottom attachment point at the very end of the wheel well. Is there a bracket or something to attach to? Anyone have a diagram or pictures. Also, what does the decklid attachment point look like? Thanks
There's a small u-bracket welded to the frt edge of each rear wheelwell. They sometimes break off and are inexpertly repaired by owners or shops. There apparently were two different brackets because if you flip the struts upside down on some cars, there's interference while others can be run upside-down with no problem. There are also two different sized bolts that were used, one assembly having a steel bushing. Reason we run struts upside-down is, water thrown up by the tires tends to collect on the top of the strut, and with OEM struts, the rubber boot was not tight to the rod so the water got underneath, rusted the strut-top and rod, destroying the seal. Finally, do NOT run too stiff a replacement strut: it is possible to bend the roof panel with too-stiff shock-struts (such as are 'recommended' for wings etc), and that area is extremely difficult to body-repair.
