Has anyone here measured the header temperature near the ports on their headers? What reading did you get?
quote:Originally posted by Rob Borruso:
Doug,
Have you considered adjusting jetting? You can cool it down by adding fuel....
quote:Originally posted by pantera chris:
Questions,
Aluminum heads? rpm at idle? cam?
have you done a Leak down and compression test, even a exhaust gasket undersized can effect exhaust temperatures.
Any pr-ignition knock?
By the way I had very strange and varying problems with Champion plugs,I now swear by Autolite. Dropping the plug temperature will in turn cause a richer burn. You can do the WD-40 test on that intake, that could enplane allot if you have any leaks
Last question, does the engine overheat? May not be a problem.
This may help these are EGT temps @ 3200 rpm average 1200 F
high # 1 @ 1274 low @ 1118 #3
6000rpm ave. 1348F high 1429 #1 low 1281 #3
light brown plugs.
this is my 395ci stroker. # 64 plug.
quote:Originally posted by Rocky:
Here Doug -
In the spirit of Christmas....
Maybe this will help.
(Be Kind!)
Amazon - Tuning Made Easy...
quote:Originally posted by brother-bee:
Comp2. Could you go into more detail on pairing of wrong cylinders.
Hi Doug,
I follow the never to old to learn philosophy.
That said, I learned so much from the D.V.D.s
offered from this company www.AutoShopVideos.com
The explanations are easy to understand ( even for me ) and it turned my Holly nightmare into, I can fix any Holly!
Anyone who wants to come out of the ditch on corroborators can do so with these D.V.D.s
The D.V.D. I ordered was "Performance Corroborators " it cured my ignorance,
I highly recommend them. I have now fixed and now they run perfectly four carbs!!! the old saying that you can't teach an old dog new tricks is B.S.
quote:Originally posted by 4V & Proud:
a Jedi mind trick
quote:Originally posted by comp2:
The Innovative motorsports LM-2:
http://www.innovatemotorsports.com/products/lm2.php
I have an earlier version, the LM-1 I have used on many vehicles including my tractor. A few cars I actually added a O2 gauge and a vacuum gauge.
I thought you might like this. The O2 gauges are getting quite abundant. I did not want it on the dash in the MGB (Chevy V6) so I installed it behind the radio delete plate which is held on with magnets:
quote:Originally posted by PanteraDoug:
I like it but what do you do for entertainment? Sing?
A hotter plug is one that permits a higher combustion temperature. A colder plug colder combustion temps.
quote:A hotter plug is one that permits a higher combustion temperature. A colder plug colder combustion temps.
