Just wondering if you have any ideas
headlights will not go up
I pulled the motor, it works - I have the plastic gears but all is fine - I replaced my micro switches -
I installed everything - I had the lights 3/4 up upon install - I started the car the motor put the lights down - I turned on the lights - did not go up - note the light does not light while down
All fuses look good
should the light slight up even though they will not raise ? could it be my light switch ?
I looked at the light relay but do not see an easy way to get it out -
If I unplug the two wires on each micro switch - would there be an easy way to jump to the battery to get lights to go up - could I jump to battery and use the micro switched so that I do not have the motor lowering after lights are down - I do not want to further hurt anything...
Thanks for the help
