With all the recent project action in the Pantera section, it seemed like a good time to post a few images of my (still incomplete) custom induction setup for #1010. If ANY stock carb or manifold parts had come with the car I would likely have dutifully returned it to stock, I thought it would be more fun (?!!) to try something different.  I wanted to run Webers, but didn't want to omit or modify the OEM jackshaft, so IDAs and IDFs were out of the question.  After debating various options, DCNFs seemed to make the most sense, being compact enough to sit in the valley, allow a RH throttle pull, float bowls in the 'proper' direction, and leave the jackshaft totally untouched.
Obviously no manifold was available so it needed to be welded up from whatever made the job as simple as possible. The basic concept was to adapt the top of a Maserati V8 manifold to a Ford tunnel ram bottom, but in practice the dimensions were not all optimal, and the final solution was to cut things into smaller bits and include some Aston Martin V8 manifold parts, including the forward carb perch, which was shaped differently than the Maserati design.
There was still a lot of fabrication to get from circular carb outlets to rectangular intake ports and keep the transition shapes respectable in all eight runners.  Also it came clear that there was no way to fit a standard distributor b/c the forward carb interfered. This was solved by going distributorless, which eliminated the need to perform an service work at the front of the manifold, where there is NO space!
So things have only been mocked together so far, and the huge question remains if the motor will run well when everything is ready and first started.  If it works it should sound great  The manifold provides vacuum for the brakes but does not yet have a PCV provision, which I want to hide on the underside of the manifold. Beyond that, fingers are crossed and hopefully a real test will happen in the next few months...…here are a few pics, enjoy!
20
13
16
15Goose 1010 engine bay 20171210 cGoose 1010 engine bay 20171210 dGoose 1010 engine bay 20171210 n14
Images (8)
  • 20: Work underway....
  • 13
  • 16: DCNFs with air horns
  • 15
  • Goose 1010 engine bay 20171210 c
  • Goose 1010 engine bay 20171210 d
  • Goose 1010 engine bay 20171210 n: Modified Maser Qporte filter box
  • 14: "Power Bulge" (swaps w/ stock cover)
Great job with fabricating the intake manifold. The Webers, of course, look gorgeous.
There are 8 port "distribution blocks" on the market that are perfect for the PCV manifold . Tack it to the bottom of the manifold, plumb it to all 8 runners from underneath. This one is Edelbrock #76578.
edelbrock 76578
Another neat trick for Webers (individual runner induction) is a separate electric powered vacuum supply for the brake booster. It eliminates the power brake vacuum plumbing as an eyesore or a plumbing issue.  Providing vacuum to the booster this way is common these days for electric cars, customs, drag racing, turbo & super charger applications.
A few OEMs have small, quiet, electric vacuum pumps. Add a small tank for volume & a vacuum switch to turn the pump on & off. I think there are some all-in-one units too; Audi may have one that is popular. It is possible to make this look as OEM as you have the Induction system & air cleaner assembly.
Mount this vacuum "assembly" below the car, immediately under the brake booster. All that is needed is a 12 volt wire for power, and a short vacuum hose to the booster.
  • edelbrock 76578
The Maserati Bora has the same Weber carbs and air cleaner system.  If you read thru old posts about Panteras' with webers and the problems such as not holding tune / sych, lighting filters on fire etc.  I have had none of these problems with our Bora.  I suspect your set up will perform similar to our Bora.  If it does you will be very happy.
All, thanks for your thoughts, I really appreciate the encouraging words!
Re the carb angles the goal was to retain exactly what Maserati did since that allowed use of the factory throttle linkeage (modded for carb #2 only) as well as the main air box structure, as Italford recognized (different snorkels only required).  I assume the reason Maserati did it was that the RH cylinder bank is slightly forward of the LH bank, so 'opposing' cylinder ports sit at that funky angle.  As I recall Aston Martin has the same basic architecture, and fortuitously it's all exactly like FORD architecture...so keeping the angle was definitely the path of least resistance from a fabrication standpoint.  It also promoted the straightest shot from the carbs to the intake ports.
George, thanks for the Edelbrock idea, like that approach lot. My tunnel port foundation is a bit short on meat where the tubes would connect but I think adding some weld material there would make this possible.  I've definitely learned that compromising on PCV features is bad on a streetcar, one of those things that comes back to haunt you later...
As for the extrusion machining...... I momentarily thought the video link was a preview for some new sci-fi movie.  Amazing tool for sure!
Nate,
Lee just mentioned this intake adventure in the post about "old pictures" and I finally found this!  WOWWWWW! Is all I can say!!!
Not sure where I was when you posted this, but it may have been when I was moving, prepping old house to rent, finishing new house to live in, struggling with NO internet bandwidth allowance plan.....glad most of that is thru...!
But WOW!!!!!  That is gonna sound insane!  You need a clear lid for the thing.......and or the provision to go "lidless" for short jaunts!
Glad you were able to preserve as much of the Goose features in doing this, especially after all the REST of the work you're doing or have done!
Steve
It is possible to fit 48IDA Webers and use a jackshaft just not the original jackshaft.
We have this installation on our car.  Used thick wall chrome moly tubing and with 2 x bearings (no centre bearing) with stout alloy brackets.  Still testing Webers vs Holley (we need to change the cam to suit Webers as getting too much reversion / stand off as we call it in UK).
Initially we worried about whip of shaft with just 2 x bearings but critical speed calculations should  mean it's safe in operating range we are using, if not we can adjust pulley ratios to slow jackshaft speed vs engine speed.  Alternatively its not that big a deal to incorporate a centre bearing coming off one of head / inlet studs.
Installation allows both alternator and a/c (a Standen) pump to run in original location (not shown in the long shot pic yet as A/C not installed for racing).
Torque with this set up is immense!!
Images (2)
  • IMG_0923: (before jackshaft installed!)
  • IMG_5757: Close up of brackets
V8J,
There is a Goose (#590) running around, re- sold back in the 90's, with a Gurney Eagle top end where the installer was able to utilize the jackshaft also!  I think it went in the center under the carb.
It appears that your bellhousing has had the RH mounting boss removed, making it difficult to move the alternator to that boss.
While alternators mounting in the RH area are uncommon, my car (#878) had it there with no apparent evidence that it ever was in the center position.
Of course once you choose a center position, you have things like the distributor, possibly the water outlet, and the water pump pulley to deal with!!!! Never a free lunch......  I am not sure how the builder of #590 dealt with this....no pics!
If you do need a center mount for the jackshaft, you will definitely want an adjustable version......as this has been hashed around on this forum quite a bit...... with aluminum manifolds & heads now more common, trying to keep three holes in perfect alignment is near impossible.  I really don't understand how the Italian builders made it happen such that we don't see reports of busted jackshafts in early writeups.
My own experience was such that I just tossed the center bearing idea in the rotary bin as what I did on the intake off the engine wasn't even close to how it turned out when mounted (alloy intake), and another owner, with stock cast iron engine, broke his shaft in two....with probably at least one more instance in more recent times!  (I had a jackshaft bracket made of 1/2" steel (Boss 302 engine) and the shaft installed easily indicating pretty well aligned.....but still shucked that center bearing after 15-20K miles on it....)
I never experienced any vibration issues with my new 331 and only the end bearings. But my shaft had already been rebuilt/replaced before I bought the car, so was not a stock shaft.... materials could have been better(?).....   Spinning that engine up to 6K would put the shaft speed at around 7K or so with the pulleys that were utilized (fairly common versions).   The bearings are definitely rated for way more RPM than that......
Nice job on your car!!!
  • joseengine
Thanks for that Steve, do you (or anyone else ) have a picture of the Bellhousing which has the RH boss intact with alternator removed so I can see where mine differs?  To be honest I was ignorant of fact that mine had been modified along the way!
And I should have said to Nate that his solution is far neater than the IDA's (especially the airbox) but not an option for us as our regs stipulate IDA's.  Although jury is out on Mangusta as a race car at moment....
Nate, have you run your car ups yet?  Compared to the 289 in Mustang the Mangusta struggled to breath well over 5,000 rpm, either cam needs changing to suit Webers or the headers are small than the Mustang which isn't allowing gases out There's always something!!
Here ya go!  Pic from "engine (Boss302) out" number 2,349......ok, number 2.... during my frame repair operation..and enginedectomy...trans had just come out. I thought I had a pic of my NOS "clock holder" somewhere....but can't find it.....yet....
Bummer that you are not allowed use of other period downdraft twin carbs.....
As for the 302 in our cars and revs......
1) the puny header size did NOT help at all.......these headers resemble old household heating system pipes repurposed as auto parts......
2) the heads are fine....right up to the fairly small exhaust ports.   A simple "gasket match" porting job brings them a bit more to life.   A full on porting job, as seen in the GT40 heads (different post somewhere on this forum....) brings them up to damned good.....no need for other heads.  Some would argue that the intake valve sizing should be increased....... likely for little gain in our butt dynos.....!!!   Intake ports are huge already.  Combustion chambers are closed style..... 68 heads are best SBF cast iron that Ford made along with HiPo289's....which still fit in our cars.   Boss 302's do NOT fit........just ask me how I know this......!!!  )))
Air injection system can stay on the car with minimal HP loss (pump drag), only physical clutter. Clean up the air...... )
What was never made for our cars, was a version with larger long tubes to emulate the look of the stock headers.   Several versions of larger tubes.....but they resemble typical 4-1 design.  Nothing wrong with that, just little resemblance to originals. IMHO.
3) The cam was pretty mild and of no assistance. Pretty much done by 5000-5500.   A HiPo 289 cam or the Ford OTC performance cam would have livened these engines up quite a bit!  Something borrowed from the GT40 or Trans-Am cars would have been nice......
  • dayfour5
Great fabrication and design.
Here's the thing though. The reversion is not caused by the carbs. It's caused by the cam timing events in a V8 with individual intake runners.
Changing to another carb other than the 48ida doesn't fix the problem. It's caused by the individual runner intake manifold.
The fires are not caused by the carbs. What happens is that the reversion pushes back the atomized fuel and that gets collected by the air cleaners.
The fuel saturates the filter elements. They get soaked with fuel.
When you go to restart the car, the ignition flame travels up the intake runner and ignites the saturated filters.
I like what you have done with the fabrication of the air cleaner but you are going to have to put the filters, not over the carbs but at the extreme end of the flexible air supply tubes and pray that the fuel plume doesn't reach that far.
You are also going to need to provide some sort of a drain in the base of the air cleaner and some sort of collection mechanism to collect the fuel in a way where it can't ignite. If you don't then you likely have created an explosive device in that air cleaner?
A Ford 302 is not a Maserati engine and has different characteristics.
As I said though, beautiful fabrication work.
I also have seen two racing Mangusta's running a 48Ida system using jack-shafts. Just not original ones and mounting brackets although still a simple system. I have no details on those though so I can't offer any help on specifics. Sorry.
Carry on!
Agree, the short individual intake runners  make the problem much more pronounced than. Interestingly although we don't have a reversion / stand off issue when we switched to the Holley we still have a breathing issue which points to headers.  Over winter our plan was/is to switch to a cam which has a bit less duration , which we see causes the problem, and a bigger lobe separation angle which should also alleviate it.  If we swap our cam and the issue is alleviated we'll report back.  May also put engine one dyno and swap out the existing headers for the 1 5/8ths we use on Mustang and see what that produces before embarking on having any made.
GT40's run "turkey trays" so at least you stop the drips getting onto exhausts - that's then theory anyway and I was told if you see flames hit the throttle and it'll suck them into the engine.... okay...
Hopefully not hijacking the thread but we got confirmation today that our car has been given an FIA Historic Passport  (with the Webers on) but not as a GT. Basically it means (unless the race organisers are "flexible" which in current climate they may be!) we have to race against Lola's, Chevrons, GT40's and 917's which is, (to put it mildly) complete BS and a kick in the teeth.  We'd hoped it would open the door to lots of races and planned on going up against E Types, Griffiths Cobra etc but no, not according to the FIA we won't.  According to them it's not a GT but a Two Seat Race Car.  Utter nonsense.
So another reason we may not race the Mangusta  but having come this far with the IDA's we are stubborn enough to try and get engine to work properly on Webers whether they are IDA's IDF's or DCNF's!!
@v8jet posted:
The Holley runs with a common plenum intake manifold so the reversion pulses are intended to push the mixture into the next opening intake valve.
IF you want to see a light show, start the engine (with  the 48ida's and just velocity stacks) at night. It's very impressive and the kids will like it better then a fireworks display!
I recently went to a 2x4 Holley set up on a C60A trans am intake manifold. So I repainted the underside of the hood.
The flame marks from the Weber velocity stacks were still on the underside of the hood.
Yep. The GT40 "cookie trays" are there MOSTLY to direct the fuel plumes into a safe collection area.
Detomaso actually figured out that all you had to do was go to a 5" tall velocity stack and the plume would stay in the stack. Interesting that NO other teams ever noticed that before?
There were a few sets of 58ida's made for Ford and Shelby to run on the 427's. NO ONE could get them to "work" (at least to their sanctification or expectations) so the Mark II's ran a single Holley carb. That isn't a disgrace and in human terms is the simplest to make work.
Why fight it? Run the Holley and put yourself in a more competitive class. You can't compete against Lola's. The thing weighs like 1,600 pounds. Otherwise you are just being an alchemist and turning lead into gold never really worked out?
I think you're right on the money with using the Holley we're really pleased with the one we run on our race Mustang, it just performs and stays in tune.
I'll try the night time routine with a fire extinguisher on hand.
The situation with FIA and Mangusta  is just nuts, they complain like crazy about wanting variety on the grids, then allow at least 20 Cobra Daytona Coupe replicas to get certified, often with more in a single race than ever came out of Shelby and then tell me I need to race with cars like Lolas and Chevrons, even when the Mangusta doesn't fit their own definition of the class they have categorised it into.
Their loss, it won't appear on one of their grids with cars like that, would be like bringing a knife to a gunfight, plenty of other places to use it or just turn back into a road car.
But you have to admit, 4 x Weber's do look and sound VERY cool!! As Steve suggested to Nate a poly clear cover on top of the Maserati style airbus would look awesome.
racing Jury is still out, still feeling FIA / regs are stacked against us so will find somewhere else to go, maybe find something with other GT's. main issue is they won't even listen or enter into a dialogue.
a 292 with 620 bhp, that is a TON of power.  We have to run iron C5AE heads, cast rockers  and Tri-Y headers with C5AE block too, please tell me that has Ali heads with roller rockers before I go into major depression ......
I understand  that the Cobra Automotive / Curt Vogt Gt350 has that kind of power but think SCCA allows much more radical mods than we can run in Uk / Europe
