And just like your LS3 its reverse cooled, thats got to be good for keeping the Pantera cool.
Cubes & supercharger, you can't beat it.
(These engines in crate form are listed on the internet at $21,000.00 USD)
regards,
Tony.
Hi Tony, The LS3 definitely runs cooler which is a good thing! $21,000.00 is a good price but it could be had for quite a bit less if you wait for the right deal to come along... It is going to be a fun project. I have most of the issues worked out but I am sure there will be some additional challenges that I haven't thought of. But that is the fun of it! Take care, Scott
Scott
This swap mast be amazing, Corvette ZR1 curb weight is 1600kg/3540lbs and my Pantera (LS3) curb weight is 1355kg/3000lbs, your Z06 Pantera must be around 1400kg/3100lbs??
You must get exceptionally performance ZR1 0-100km/h = 3,6s, ZR1 Pantera =? (10-15% lighter)
My concern is how to get the throttle/intake to fit, can you turn it 90 degree to the left?
Can you later on measure the distance from c/c crankshaft or water pump shaft, to top of the charger pulley and air intake, eager to know if it will clear the frame.
Please post more picture during the swap.
burn rubber
Yngve!!!!! Good to talk to you again!!!
Yes, the power to weight ratio should make it quite entertaining to drive!
I will be doing some real world measuring today but I have already mocked it up in CAD. The intake is going to have some challenges BUT, there are several ways to address the issue.
I will be posting pictures as I go... How about you post some pictures of your beautiful LS3 Pantera?
Take care, Scott
Hi Jon,
what was the inspiration for LS7?
You mean LS9...
There must be less expensive ways to get to that power level?
Of course there is!!!
Have you seen or read about the LS9? It is a fricken work of art! It will idle unbelievably tame but the powers is there when you need it. Also VERY reliable. GM had to over engineer the hell out of it to be able to give it a 5 year 100,000 mile warranty.
And there is also the fun of doing it, just because!
I could probably get to that power level for half the cost but that wasn't my goal for this project...
Take care, Scott
Just out of curiosity, what would that mean? Thicker this and that? Different materials? Blueprinting? Or the other way around, the computer keeping the timing and mixture conservative and thereby losing power? Or all of the above?
For sure it's a powerhouse, and any non-bowtie-hater must love it. Still the price tag 5x (?) above a LS3 is a lot? But I guess "Speed is just a question of money, how fast can you go?" -Mad Max
Hi Mikael,
This project is somewhat interesting. I have gotten some really negative comments from some people on some other forums. I guess some folks don’t like the cost of the motor but who cares anyhow? I mean, it is my money, so do people really care that much about my personal finances. Anyway, I digress…
It means that they spent a lot of time insuring that it would survive a 5 year 100 mile warranty… reliability! (hopefully)
Yes
Yes
Blueprinting?
Yes
Yes
Most love it and everyone hates the price… 5x’s an LS3… WOW, I don’t think so…
Thanks for the interest! It is going to be an interesting and fun project.
Take care, Scott
Scott
The LS3 Swap changed the car drivability to be that brisk and with a supercharger it can not be other then Super.
The swap is relative easy to perform, on the minus side It is not a Ford engine Frowner but on the other side Big Grin it is a small engine that fit very well in Pantera, 250-275 lb lighter than cleveland is many "ponys" in additional to the 480 in LS3.
Yngve
  • LS3-1
In comparison, Ford quotes a weight of 315 KG's (about 695 lbs) for the all aluminum 5.4L Ford GT motor, including dry sump oiling system, although I'm not sure if that's a "wet" weight.
Scott mentions he's taken some critisism over this project, based on the cost of the LS9, however; considering the low weight, compact dimensions, power output, driveability and reliability of the motor, the cost is VERY reasonable. Jeg's sells the LS9 for less than $19,000 including shipping! It pains me to say, my Fontana aluminum block based, injected, "Ford" motor cost me considerably more to build than the "good guy" price of an LS9. The non-supercharged LS7 costs about $5,500 less than the LS9 yet still puts out over 500 HP. Slip in a new cam, tweak the ECU and the LS7 comes close to 600 HP, normally aspirated. If you don't want the complication of the LS9's supercharger or the LS9/LS7's dry sump, GM has an LS3 crate motor that's rated at 525 HP, for $7,500...with a warranty. How can you beat that?
Pretty sure the Ford GT weight figure is the dry weight but includes all the accessories(power steering, ac, alternator etc) and the dry sump tank plus clutch and flywheel. No denying the Ford GT motor is heavier. The Ford GT motor was quite a bit more expensive when it was available somewhere between $34000 and $45000 and if you paid a core charge. One is on Ebay right now for $39000. Plus the GT motor is huge. Ford Parts Direct currently is listing the Ford GT bare block at about $6600.
http://www.fordracingpartsdire...LOCK_p/m-6010-gt.htm
Scott,
I'm curious about one aspect of your LS9 project: are you planning to keep the dry sump oiling system, or will you be converting the motor to wet sump?
It seems to me, if you were keeping the dry sump, you could lower the entire drivetrain a couple of inches, which might buy you a little more room at the front of the motor. I assume you already have CV jointed half-shafts, which would make lowering the ZF a bit easier. You might even be able to lower the motor enough, so that the TB fits into the hump between the seats!
Lowering the drivetrain would also drastically improve your CG. If I recall, Jack DeRyke has lowered the drivetrain in his Pantera by a small amount.
Hi David,
I do plan on keeping the dry sump. Good point on lowering the drive train. I will be lowering everything as much as I can. I have already mocked it up in CAD and I believe everything will fit WITHOUT swapping the intake 180 like I did on the LS3. I won't have a flat firewall but it will be flatter than the stock cover...
Take care, Scott
Scott, one more question: will you be using GM's electronics/controller kit or will you go aftermarket? If GM, I guess that means using the "drive-by-wire" throttle pedal that comes with the kit.
There wasn't a GM controller available for the crate motor until this year. It was announced at SEMA I believe. I haven't seen pricing yet.
Since the GM computer would require I duplicate the ZR1 fuel system(and that system is complex and expensive), I decided to go with an aftermarket computer. Also, with the aftermarket system, I can tune with a laptop and there are a lot of cool features with the software.
The aftermarket kit is also "drive-by-wire"...
Scott, I think that what you are doing is great. I will be following your progress with great interest. Who knows,maybe even following in your footsteps. Ignore the naysayers,you are going to end up with a great car. Just do what Alejandro did and put "Detomaso" plaques on the valve covers. Jim Coyne
Thanks Jim!
