![Big Grin](/static/images/graemlins/icon_biggrin.gif)
Over the next few weeks months the hard part of putting it all back together again, wish me luck, and thinks for the likes.... ![Big Grin](/static/images/graemlins/icon_biggrin.gif)
quote:What are your cam specs? Be sure to check your Scorpion roller rockers for clearance to the pushrod. Doug Braun on the DT Mail List had an issue with contact between the pushrod and rocker body (links below) and I had the same issue with my new engine. Given that you're using a Windsor, it may not be an issue. I believe the angles are a bit more extreme on the Cleveland, but my Scorpion Race Series roller rockers were spec'd to be capable of .950" of lift, and my cam is only .588" at max lift.
Details:
http://poca.com/pipermail/deto...December/048101.html
http://poca.com/pipermail/deto...December/048138.html
quote:anyone know where everything goes? lol its been so long apart.
quote:Originally posted by JAG13CAT:
Looking good Detonator!
Question - I am in the early stages of restoration and was wondering what distributor (setup) you're using and if it will clear the bulhead?
quote:Originally posted by Rob Borruso:
Looking good Detonator... nice progress. Hopefully all your bags of parts are labeled..That should help w/ reassembly.....
quote:Originally posted by Detonator:
I still have lots of work sorting out electrical issues,headlight motor not working, power windows not working, if anyone has ideas what to look for I am all eyes n ears...also I plan to swap the ford Motorsport ignition module for a msd, interior needs putting back in, and then test drive.
Hey Detonator, congrats on the milestone. Got any vid of it running? BTW, your engine/engine bay look fantastic.
Hey to your earlier remark about your car being built with odds/ends laying around the DeTomaso plant. I've read that there were many cases a chassis would get pushed to the side for whatever reason for rework, and then later re-introduced into prodcution. I would imagine this is what happened to yours...hence early chassis elements. If they could only talk....![]()
