2511 needs a new radiator grill.
I actually have a good wire mesh screen portion, so if anyone has a good frame with a bad/missing screen mesh, that would be just fine.
Condition of chrome is not important, as grill will be powder coated.
I would prefer the early version that mounts with attached studs, as opposed to the later unit that uses sheet metal screws for mounting.
Can anyone confirm the early/late grills also varied in their size? I have received some feedback they do differ.
Trades possible - what do you need? I just might have it.
Thanks,
Or perhaps this one could be buffed out?
  • FullSizeRender_2
I see a somewhat symmetrical shape to yours? Couldn't you put one of those Chrysler turbo car noses on the car with that big round jet engine center intakes so you could still use this grill?
No one else has done that yet?
You need to put your thoughts into the abstract, then you will begin to see possibilities? Modification improves the breed? Smiler
