The next day I was ready to move it back and had to go through the same thing again getting it to run. So it went bumpbump...bumb..bumb...clunk
So, now I ask you, how bad is this going to be and where do I start?
quote:Originally posted by ht4tchr:
Hooking the VOM to the battery side of the solenoid and to ground shows the same voltage as at the battery (ie: it's hot all the time). Turning the key to start drops the voltage to 6V or so. That's as far as I've gotten so far. What does this tell me?
quote:Originally posted by PartTimeAdult:
The stumbling you describe sounds like carburator icing. It can happen as high as 45 degrees if the humidity is high,
