Originally posted by Rapid:
I think this has calipers and rotors from an older lincoln
67 Big Ford/Tbird/Lincoln. For all intents and purposes the same front brakes as the 67 Shelby Trans-Am Mustangs, the coupes.
The rotor bolts up to the Pantera hub. The only issue I see with them is that they have a US 5"-ish bolt to bolt spacing and the Girlings are 3" as most Euro brakes are. (3.3" -ish)
The Rear of the Pantera is strange. 2.4"ish. The 65-7 Mustang front calipers will fit with elongating the mounting holes. You can use the stock Pantera rear rotor or change it to the vented 65 Mustang front rotor, if you can find some? Those have been discontinued.
They are a massive setup. It would be great if they were available in aluminum (but aren't). Similar in weight to the big iron Girlings the Gp3 & 4 cars had installed on the race Panteras.
So you need to make adapters for them. Not a big deal at all.
If you aren't going to use them,
do you want to sell me would you consider selling me the adapters? Please?
I have these on my Shelby. I'm thinking this would not be a bad solution for my Pantera?
Would you happen to know if an 8"x 15" Campi will fit over that assembly?
Really nice shocks. I'm envious.
![Big Grin](/static/images/graemlins/icon_biggrin.gif)
