Originally posted by Bosswrench:
Along with what George said, Ted Mitchell has been selling no-strut deck lid supports with flat coil springs for quite a few years, that look like Detroit hood supports from the '60s. They are properly weighted and are totally heat-insensitive, using no gas at all. Check his web site www.tmitch.com. Not cheap but quality never is.
Yeah, but I like the bone stock apperance on everything..he he Smiler Smiler
If no one has experienced ill things with the Detomaso 18126A, then I may just do those. Actually with all the talk about hoods and hinges bending, I have never actually personally heard of anyone that has had that happen, or any photos.
Thanks for the Mcmasters source too. In the link below there is quite a bit of offerings, and for once, someone actually posts lbs pressure.
http://www.mcmaster.com/#gas-springs/=lx99s6
Well, from my March 15th post and earlier when my decklid shocks were not working well, my Autozone Mighty-Lift D95004 are now working fine in holding up the rear decklid. March here in CA is about 60 degrees or so and the struts still were not holding well even with that slight warm up since the chilly 40s/50s during the winter. But now that we are into June it is in the 80s and they are now working fine. So, now after seeing this happen for a few seasons, I conclude that broom handle seems to be the appropriate applcation in the winter until summer rolls around, and then struts are ok...even in CA with low temperature variance, go figure.
Originally posted by David B:
I've had mine for at least 15 years. They lift up the rear deck (with delta wing) with no effort from me at all. And it stays up. I can leave it open all day in the sun. They haven't lost anything in all these years. There's no brand name on them but I snapped this. I highly recommend them if you can figure out who's they are. I can't find any reference for that PN.
I just ran across this post.
RB8795148 is a part number but can't find the original manufacturer.
Tried Google'ing it and cross references to a 1978-1987 Dodge/Plymouth Hatchback.
Interchange Part Number: SG314005,4400,8195207,10368,8504IL,901210
Other Part Number: RB8795148,95148,613305
Sold in pairs.
The interchange part from Strongarm (PN4400)are sold in pairs for around $30 at The Lift Support Depot in San Marcos, California through their EBay store. Not sure what their normal price is.
Read some previous posts and decided to look around for new lid lifts. My existing units measured around 75 lbs when pushed against a scale and would not stay open.
Contacted Sacks and they identified several that were close to existing model.
Here's their reply;
SG314002 17.2" ext, 11" comp, 85#, 8mm eyelets
SG302001 17.4" ext, 11.5" comp, 85#, 8mm eyelets
SG314032 17.2" ext, 11" comp, 114#, 12mm eyelets
SG314003 16.7" ext, 10.25" comp, 121#, 12mm eyelets
These are the lift supports I have which closest fit your needs. You can purchase them at O'Reilly's Auto Parts, Pep Boys or Autozone. You can also find a wide variety of lift supports at www.liftsupportsdepot.com.
I purchased #SG314032 for my non-winged '72 Pantera. My deck lid has the dress up underside
so that does add a little weight.
These work perfect. Pop the hood and it raises by itself in a controlled manner and stays open. These new units are 115LBS, have the correct eyelet ends with slots that match my (i think) original double mount ends. Cost was around $23 each at O'Reilly.
Thank you for getting me on track.
2
  • 2
The ones that Hall sells as a non-stock replacement, when you cross the number over on the label, do show as that Dodge number. They also cost something like $28 each in a NAPA store.
I bought my first set from Hall. Installed them and the hinges where the attach to the decklid IMMEDIATELY pulled out of the decklid.
The only thing I could do there was braze them internally through the slit and they held. Problem is the heat warped that part of the lid.
I got that under control by shimming down the hinge mount flanges to the roof by 1/8".
I noticed that the deck was no longer pushing itself up, and was sliding down about 5 or 6 inches yesterday.
I have no wing.
I also think I see movement in the attachment of one of the hinges and the decklid.
There is NO visible rust on the decklid in the hinge area.
I haven't come up with a solution to this as I just noticed the entire mess yesterday.
Needless to say, I am not a happy camper.
I personally like the look of the original fat lift shocks.
I did hear mention that the rebuilt originals will not last for long. They seem to be a temporary solution as they quickly loose thier charge.
I personally can not verify that, since I have not gone that route.
I am going to an Italian Car day show today and will see if there are other Panteras there and what they have.
Any info on this I will post.
I am not sure how the factory originally attached these hinges to the decklid. There is no exterior evidence of that.
If the braze has not held, not sure where to go with this. Doesn't look like they can be converted to bolts.
Not a good scenario all in all.
I saw one car that has electronic lifts like on the current mini-vans. It works nice and he had it tied electronically to his key fob. I'm not sure if in the case of some type of an electronic failure the deck can be lifted manually or not? Pantera-electronics, i.e., Jon Haas has a design he makes that need an air compressor to work. I have a set here.
The issue that I have with that design is that the struts are larger in diameter then the replacement struts. That puts them too close to a couple of the tubes on my headers.
The other thing is that I'm out of room to put another compressor gracefully in the car.
I'm trying to encourage Haas to build a set of the self powered struts but as always with him, he looks at marketability and what he already has done so there is little hope there.
Every so often I look for electronic struts that would just happen to fall into a direct replacement scenario but so far the Pantera ones are too short to match anything currently in production. Of course there is always the possibility that one of the exotic companies will make them for a reasonable price of $1,000 each? For that probably the polarity will be wrong and you will probably need to rewire the entire car to make them work for sure?
The only thing I could do there was braze them internall through the slit and they held. Problem is the heat warped that part of the lid.
I have no wing.
I did hear mention that the rebuilt originals will not last. They seem to be a temporary solution as they quickly loose there charge.
I am not sure how the factory originally attached these hinges to the decklid. There is no exterior evidance of that.
All of this is easily solved once and for all with a pair of IPSCO units. But alas, they are not in the stock location (because they are engineered to be an improvement).
Yeah, my Autozone Mighty-Lift D95004 finally gave out, even in hot weather. They do hold up only when nice and hot after running the car. After buying a few sets of these, it seems the life on them is about a year or two. I even used heat reflector on them when I drove the car, as I thought the heat was ruining then, but that didn't seem to help their life. I would consider going back to those sold by some vendors labeled "Detomaso" as described here earlier, but I measured the pressure as stated here before and it is up to 160lb under compression Seems way too much to me. I have found 110 is the sweet spot for non wing car. So for now just using the manual strut clamp to keep it open. I think George posted a source to build some custom struts, so I may try that. Pain in the butt, as it isn't really that easy to change them out without overextending the hood or screwing up the hinges.
DOES 200, We spoke after I bought my Pantera about 5 years ago. So how many Pantera's make a decent retirement fund?
From these past posts - most thought 90-100 lbs per strut would be perfect. The Sachs unit I purchased bolts right up and have 115 lbs for $23 each. I can lower the lid with one strong finger.
Best to you and the board.
Haha Weber, there is never enough for retirement, although 3 is getting close. I went to the web on yours, but they show 125lb. shown below.
http://www.liftsupportsdepot.c...mbers=SG314032&pns=1
Are yours still holding up? Nice engine bay by the way! The wife says I don't remember important things anymore, but I think your car was a real nice GT5 build.
Good options from others too, but I want something in the stock bracket position unless I cut off the brackets and repainted.
Jon Haas's set fits right into the original brackets. No repainting needed.
The original fat dust boots fit right on.
The only difference is he left his natural machined aluminum.
I saw it yesterday but took no pictures.
I do believe that he has a video of them on his Pantera-Electronics web page? Take a look.
He hasn't answered me yet as to whether on not I can get a set from him. Soon.
DOES - Here's O'Reilly link for the Sachs lid lifts.
http://www.oreillyauto.com/sit..._-1&keyword=sg314032
Here's their web description.
Sachs Stabilus - Lift Support
Part Number: SG314032
Line: SAC
Limited Lifetime Warranty
UPC: 19495086277
Compressed Length (In): 10.965 Inch
Extended Length (In): 17.185 Inch
Lower Mount Type: Eyelet
Travel Length (In): 6.220 Inch
Upper Mount Type: Eyelet
Detailed Description
Manufactured to automotive O.E. performance and quality specifications. Restores the original opening and closing speeds of your hood, hatch or trunk. Easy to install. No special tools required. Exact replacement, engineered for your application. Rust-resistant piston rod extends product life. Easy lifting, reduced closing effort. Consistent lifting force through 50,000 cycles.
Additional Details
Color: Black
Compressed Length (mm): 278.511mm
Extended Length (mm): 436.500mm
Hardware Included: No
Pounds Of Force (Lbs): 115 Lbs.
Rod Diameter (In): 0.315 Inch
Tube Diameter (In): 0.748 Inch
Type: Gas
Regards
Line: SAC
UPC: 19495086277
Additional Details
Color: Black
Type: Gas
Regards
Well I've got the Sachs alright and 50,000 cycles? Come on. Maybe a couple of hundred then they're fashizille!
The deck is dropping down a good 12 inches BUT you sure can see them pushing the hinge up when it is closed?
I need my new electric cow bell. Can't wait until it gets here.
Hi Doug,
Sounds like you've been down this road a few times. DOES asked a question and I responded with the unit I recently installed. My previous units were a weak 70 lbs and couldn't keep it up. Some here mentioned the stiff 135 units were overkill. Some mentioned 90 to 100 lbs would be perfect. So I bought the SACKS 115 lbs units. They lift and close easy and I'm not seeing any lid bow due to compressed pressure. They are an exact fit to my original body hardware and cost $25 each delivered.
I also machined some SST end bushing that center position the units.
I'm a newbie and made the best decision based on this board of which you contribute some pretty good advice. I'm guessing I'll be addressing this again in a few hundred cycles.
I'll try to add a few pictures for fun.
Regards to all.
DSC00403
  • DSC00403
I am actually working on lifts that replace these struts. They work with an air pump.
The advantage with these is that when the deck lid is closed, there is ZERO pressure on the decklid. That's a big plus.
The other thing with them is that they work off of a dual frequency "remote". One frequency is for the door locks, the other opens the rear deck/trunk.
What's also neat about this setup is 1) it's very easy to install 2) the cylinders look just like the original Detomaso units with the accordian boots and all and they leave the original trunk lock in place.
The compressor is here, the hardware is here, I'm just waiting for the cylinders which are currently on back order from the manufacturer.
This is all ok since it is letting me catch up on all the yard work caused by this last nasty winter. It did a lot of little damage that went unnoticed because everything was buried in ice and snow for so long.
In the meantime, I need to replace the two Sachs struts that are in there now.
This is all ok at the moment. If it goes into June I'll start to get a little impatient with waiting.
Well I just read ALL 19 pages, and still no real wiser.
mine are on their way out, but does stay up for now.
I don't want too stiff ( has a delta wing )
i do NOT want air or electric, has to be neat or invisible.
I thought I saw a chrome one on here, but can't find it.
At the moment a polished stainless slotted tube is winning this argument, but i don't have anywhere to store the tubes !
