Today is the big day! I bought a ZF -2 off ebay. It should arrive today. It has been out of a car since 1980. What should I do before installing it? 1362 has a dash 1 now. I have the dash2 clutch disc and bellhouse, Thanks M Menson, and the correct pilot bush. The bottom cover was removed for inspection before delivery. Thanks Parapantera! I'll be using PI side mounts. They are simple fabricated angle pieces that bolt to the swaybar mounts. I talked to a vender and told him I was going to saftey wire the ring gear, he said that is not nessisary unless the original bolts have been loosened. The original bolts have teeth that bite into the gear. Any thoughts are welcome..??? Bill
A VENDOR TOLD YOU THAT??!!! Eeker
Was that a Yugo vendor? Big Grin I can not imagine any Pantera-knowledgeable vendor telling you that.
Yes, the stock ring gear bolts do have 'teeth', but due to the hardness of the ring gear, those teeth do not really get a bite. When they loosen, they begin to back out. Everything is fine until they get out far enough that on the next rotation they find a portion of the case to be slammed against. Being a very hard alloy, they (thankfully) snap off instead of jamming. And if the gods are smiling on you, that bolt head harmlessly falls down to the bottom of the case. But the gods are not always kind.
I will never forget the PCNC member who showed up at one of our tech sessions with a small Ziploc baggie. In that bag were ten bolts heads and five bolt thread sections.
He had used a coat hanger to fish all those pieces out the bottom drain hole of his ZF, after one piece plopped out into the oil drain pan while performing his first oil change on his newly acquired Pantera.
Amazingly, the only damage was a case crack, apparently caused when a piece was flung against the case, that was not of major concern. He was one of the VERY lucky ones.
Pantera Land is full of other incidences of bolt heads falling out during an oil change and cases ruined when they were cracked after a bolt head became jammed in the gears.
Bill, many owners have bought the safety-wiring kits (bolts and tool and wire) and done it themselves. Apparently it is not rocket science. I suggest you call a real vendor and order that kit.
The 'vendor' who gave you that advice is either ignorant or does not like you. Of course loose bolts need to be tightened - genius advice, there. The big question is WHY would they become loose? Because there was a design flaw, and they DO loosen.
The problem is you cannot check ring gear bolts with the ease of checking the engine oil. Your first hint of a problem may be the horrendous bang when your case cracks, gears are destroyed, and you find yourself (hopefully) at the side of the road with that nagging voice in your head...
'Why did I listen to that STUPID vendor?"
  • Picture_4
Put a bell on it. Roll Eyes
I've been using Redline MTL in all of my cars with manuals, except the Pantera. I just haven't got to it yet.
Gary Hall told me to try it a while back and I can tell you that it is a very interesting formulation.
It makes shifting easier but more precise, like it was a new gear box. Frankly, my ZF could use a little of that medicine.
If you go to their web site you will read the reason it is made. I suppose to paraphrase it, it is fully synthetic gear lube, with special friction modifiers added for the synchros.
See. Full synthetic gear lube is too slippery for your synchros and they won't slow down the spinning gears properly. It's kinda like oiling your brake pads. The pads need friction to work.
The MTL has those friction modifiers and makes the trannie feel tight and precise. Like I said, my ZF can use that.
Only the forged steel units do this. Seems to be normal for them? I do not think it was slipping. The steel gets hot spots on it. The stock iron doesn't do this as much. You really don't need a steel flywheel. They are a major PITA to resurface.
You have to use a diamond studded surfacing wheel and make about three passes just to get it flat and the hot spots out.
Next time I'm going to an aluminum flywheel.
Try a 3/8 npt tap (plumbing size). Looks like it is the right one. They are cheap and you can get them in a good hardware store. Should be $10.
If you can't get it to press the bushing out then you can thread a pipe fitting into it that you can grab with the puller.
Common Billy, this ain't that hard? Big Grin
Doug, The internel is smaller than the roller pilot that came out. I broke a tap in it. Figures, I went back to the outside slots.. This finally worked. Everyone should know that the peice I took out is an Italian bushing that extends the back of the crank and hods the pilot bush for the dash1 only. Dash2 does not require this piece because the output shaft is LONGER. And a larger end tip that penetrates the bush.
  • pilot_removed_001
It's pretty but your clutch is going to slip on it.
There are specs for the clutch that require a certain finished grit on it.
I don't remember it but the shop should know this.
The steel flywheel require a diamond stone cutter to do it right. Mine required three passes.
Few shops use the diamond stone. It's too expensive and very few people have steel flywheels these days.
From here it looks like steel. As soon as I saw those hot spots I said to myself, "yup, steel". Just an incorrect reaction. Sorry.
I do not really consider myself a clutch expert.
Let me explain my own personal experience with clutches. 1)Ford Van, 302, 5 clutches 2)92 Taurus SHO 4 clutches 3)98 Contour SVT Vortech Supercharger, 4 clutches 4)73 Pantera, 2 clutches
5)68 GT350, 3 clutches 6)67 Shelby GT500, 1 clutch. I think I got them all?
What did Jimmy Hendricks say? Are you experienced? I think I qualify? Big Grin
The flywheel looks to shinny? I think it is gonna slip? Confused
...oh and as the Southern Evangelist might say, "Brothers and Sisters, I feel you pain!". Wink
...Yes, Pilot Bearing; Right! Did You try the NEW Bearing on the -2 Input Shaft, Dia.= .6695" (17mm)? The Dash 1 has a Smaller Input Shaft at 15mm. I Machined one Pilot Bearing for a Customer with a Beautiful GT-40; the Machine had a different Brand Transaxle than the ZF, That Input Shaft was Only 12mm in Diameter!! The Flywheel will Not Slip!! Just BE SURE to clean Both Surfaces; Flywheel And Pressure Plate, with 'Lacqure Thinner' before Installing. And have You touched the 'Disk' with Your Fingers Yet?? That's a No-No, Nothing touches the Disk; and Do Not try to clean it! You pick the Disk up with a finger through the center hole. Any grease on the Disk face can start it slipping...
Originally posted by MARLIN JACK:
...Yes, Pilot Bearing; Right! Did You try the NEW Bearing on the -2 Input Shaft, Dia.= .6695" (17mm)? The Dash 1 has a Smaller Nose... some are 15mm and others are 12mm! The Flywheel will Not Slip!! Just BE SURE to clean Both Surfaces; Flywheel And Pressure Plate, with 'Lacqure Thinner' before Installing. And have You touched the 'Disk' with Your Fingers Yet?? That's a No-No, Nothing touches the Disk; and Do Not try to clean it! You pick the Disk up with a finger through the center hole. Any grease on the Disk face can start it slipping. You Did ALL those clutch replacements? I wonder if You did any Correctly? Proves one thing!! Your Experienced at Burning them Up!...
Thanks Marlin. You're such a pal. I didn't burn them all up. I had help. Big Grin
Were they all done correctly? Hum I'll send you the DVD's and you can grade them for me? Wink
I will say that out of the three Centerforce clutches I've done, the only one that has not caused some level of grief or disillusionment is the Pantera.
As it was explained to me, the clutch that we have now is essentially the same as what was initially invented for an engine that only fully developed 30 hp.
That factor right there explains alot of where the issues come from. That and the fact that when you are behind the wheel of a 500hp vehicle there is a slight tendency to want to stretch ones legs and worry about tomorrow, tomorrow.
There are some thing that clutches just don't like, amongst them things like nitrous oxide, superchargers, Weber carbs, sticky tires, front wheel drive. Big Grin
Oh, and it isn't that they don't like me, they just heard that I take a lot of them in, along with cats, and they want to help their homeless friends find good homes, and they know that will happen here. Wink
Bill,
The ZF shift shaft and axle/u-joint is a fixed dimension, so the trunnion in your early car must be in a different place creating the angle. Take a photo of that and maybe it's as easy as use a slightly longer trunnion or change the mounting point.
My trunion is all the way down and worn.
While you are waiting for a new trunnion, try adjusting it up to see if that solves the problem. Also, check for clearance forward of the trunnion .
If you still need more clearance, try your suggestion of turning the shaft end for end so that the adjuster is forward instead of aft.
If you haven't done so already, start soaking the bolts and the shaft ends where they enter the u-joints.
John
