From here it looks like steel. As soon as I saw those hot spots I said to myself, "yup, steel". Just an incorrect reaction. Sorry.
I do not really consider myself a clutch expert.
Let me explain my own personal experience with clutches. 1)Ford Van, 302, 5 clutches 2)92 Taurus SHO 4 clutches 3)98 Contour SVT Vortech Supercharger, 4 clutches 4)73 Pantera, 2 clutches
5)68 GT350, 3 clutches 6)67 Shelby GT500, 1 clutch. I think I got them all?
What did Jimmy Hendricks say? Are you experienced? I think I qualify? Big Grin
The flywheel looks to shinny? I think it is gonna slip? Confused
...oh and as the Southern Evangelist might say, "Brothers and Sisters, I feel you pain!". Wink
...Yes, Pilot Bearing; Right! Did You try the NEW Bearing on the -2 Input Shaft, Dia.= .6695" (17mm)? The Dash 1 has a Smaller Input Shaft at 15mm. I Machined one Pilot Bearing for a Customer with a Beautiful GT-40; the Machine had a different Brand Transaxle than the ZF, That Input Shaft was Only 12mm in Diameter!! The Flywheel will Not Slip!! Just BE SURE to clean Both Surfaces; Flywheel And Pressure Plate, with 'Lacqure Thinner' before Installing. And have You touched the 'Disk' with Your Fingers Yet?? That's a No-No, Nothing touches the Disk; and Do Not try to clean it! You pick the Disk up with a finger through the center hole. Any grease on the Disk face can start it slipping...
Originally posted by MARLIN JACK:
...Yes, Pilot Bearing; Right! Did You try the NEW Bearing on the -2 Input Shaft, Dia.= .6695" (17mm)? The Dash 1 has a Smaller Nose... some are 15mm and others are 12mm! The Flywheel will Not Slip!! Just BE SURE to clean Both Surfaces; Flywheel And Pressure Plate, with 'Lacqure Thinner' before Installing. And have You touched the 'Disk' with Your Fingers Yet?? That's a No-No, Nothing touches the Disk; and Do Not try to clean it! You pick the Disk up with a finger through the center hole. Any grease on the Disk face can start it slipping. You Did ALL those clutch replacements? I wonder if You did any Correctly? Proves one thing!! Your Experienced at Burning them Up!...
Thanks Marlin. You're such a pal. I didn't burn them all up. I had help. Big Grin
Were they all done correctly? Hum I'll send you the DVD's and you can grade them for me? Wink
I will say that out of the three Centerforce clutches I've done, the only one that has not caused some level of grief or disillusionment is the Pantera.
As it was explained to me, the clutch that we have now is essentially the same as what was initially invented for an engine that only fully developed 30 hp.
That factor right there explains alot of where the issues come from. That and the fact that when you are behind the wheel of a 500hp vehicle there is a slight tendency to want to stretch ones legs and worry about tomorrow, tomorrow.
There are some thing that clutches just don't like, amongst them things like nitrous oxide, superchargers, Weber carbs, sticky tires, front wheel drive. Big Grin
Oh, and it isn't that they don't like me, they just heard that I take a lot of them in, along with cats, and they want to help their homeless friends find good homes, and they know that will happen here. Wink
Bill,
The ZF shift shaft and axle/u-joint is a fixed dimension, so the trunnion in your early car must be in a different place creating the angle. Take a photo of that and maybe it's as easy as use a slightly longer trunnion or change the mounting point.
My trunion is all the way down and worn.
While you are waiting for a new trunnion, try adjusting it up to see if that solves the problem. Also, check for clearance forward of the trunnion .
If you still need more clearance, try your suggestion of turning the shaft end for end so that the adjuster is forward instead of aft.
If you haven't done so already, start soaking the bolts and the shaft ends where they enter the u-joints.
John
