While searching for some connecting rods for the 351C I’m building I found a rod from Eagle with the following data:
  • 3.210 crank pin
  • 0.912 piston pin
  • 0.8315 b.e width
  • Note: use ford 351W rod bearing
Why must 351W rod bearings be used and can these rods be used with a stock crank?
Thanks
Fredrik
