I have removed the engine to have the sump plug leak repaired and to change the rear oil seal.
after draining the oil and then going to clean the sump (oil Pan?) I found in the bottom, floating around a roll Pin (mills pin) its a
sixteenth of an inch diameter, and three quarters of an inch long.
It appears completely undamaged, does anyone have any idea where it has come from.
No other debris was found.
Best Peter
Peter,
Are you sure it's a roll pin and not a roller from a needle bearing?
If it's a true roll pin I'd go with distributor too. Maybe it was double pinned (as it should be) but the second pin was too small a diameter and came out?
A quick check pulling the dizzy should be easy enough to rule out or not.
woow now I am getting curious..as have NOT so far attached the NEW Steal gear to the distributor shaft. So my Question have a Motorcraft Distributor.
1) I have not seen anywhere the advise for TWO role pins ..please clarification
2) where do I get a new Role pin, best would be Summit any advise?
in europe we have pins which are only 320 degree and onla layer only so no real role pin..
please help...
Matthias
advice for setting the position of your new gear;
install the new gear on the shaft but intentionally leave it a little low on the shaft (there should be sufficient drag on the gear to keep it held in place)
now do a test fit install of the distributor with the gear loose & low on the shaft
INSTALL & TIGHTEN THE HOLD DOWN CLAMP as it will be when the distributor is in the engine for the last time & ready to drive
wave your magic wand
now remove the distributor and measure the minimum distance from the housing base flange to the bottom of the gear
this is your Total Interference Distance (TID)
now by measuring the distance from the tip of the shaft to the bottom of the gear you can set your Installed Height by moving the gear upward on the shaft by the amount you determine to prevent the gear from binding on the thrust surface in the block
it matters!
unfortunately some distributors that comply within the Ford & MSD spec still bind due to lack of clearance to the block thrust surface ... thus my suggestion to fit any new distributor / gear directly to the engine
Yeah it sucks but that's what's out there, been there done that found out the hard way & too late that my Mallory Unilite was binding. and that's another contributing factor to the DGRP phenomenon, severe drag caused by binding the dizzy under the hold down clamp. FWIW a dizzy will give no indication that there's no clearance until you snug the hold down clamp, it makes a big difference compressing the O ring
like i said YMMV, i can't say it any different. it's gotta be checked
too bad the old Cobra Lads site went down they had an excellent write-up about it
