Dear Pantera brothers,
I bought #3331 18 years ago (as I’ve posted on here) and she’s been doing great. She was becoming hard to start a few weeks ago so I figured it was time for a tuneup. I’ve only put 20,000 miles on and this is the third time I give her a tuneup. She has a restored original engine when I bought her and has dual point ignition with a 650 cfm Edelbrock.
When I bought her I did the dwell and gap adjustment and determined they needed a 0.019” gap. She’s run great all these years. Like usual, I did the sparks, wires, points, distributor cap and rotor. Fuel filter and hoses. Nothing exotic, I made no changes to anything else, just like I did before. I finished and now she pops but will not start. This didn’t happen the other times.  Any help would be IMMENSELY appreciated 🙏!!!!
So frustrating since right now is the perfect whether to take her out here in NC.
Thank you,
William
Videos (1)
IMG_1169
Great question! And yes, the obvious one. I made this cheat sheet of the distributor connections when I did the first tune up, and yes, I’ve checked the wires TWICE! (Against the sheet 😬) Take a look and see if I did something wrong. The cap only fits one way with the cutout on the side (I think).
  • IMG_9857
Of course, you have heard of the stock distributor pin shearing…. I had a case where it didn’t shear completely, but enough to significantly retard the timing…
So anyway - that’s another thing to look at, but if you do the timing checks, as suggested above, you will find if that’s the problem…
Anyway, my real point in is that a sheared distributor pin doesn’t ALWAYS result in your distributor not turning…. It can still get bound up, and your timing will continue to retard, until it eventually fails completely…. But until it fails, you are chasing a timing problem..  you reset it,  and then a week later you’re having the same paganism!
Good luck!
With dist cap off and rotor removed have someone crank the engine while you watch for sparking at one set of points. If no spark make sure that all the connections to the point are not grounded. Some people think that both sets of points should spark but that is incorrect. Only the last set to open will arc. Let us know what you find.
...A 'Good' Condenser is there to keep the points from Arcing. A 'Clean-Break' of the Current to the Coil is necessary for a Healthy Spark, through the D. Cap to the Plugs. With 'Arcing' of the points, there is Not a Total Collapse of The Magnetic Field within the Coil, That Creates the Spark. The Spark is Not Healthy. Should be a 'Blue Flame'.
Everyone is putting in Their Guess, of Which of a Dozen Failers can Cause a 'PoP', without Starting.
This guy has a lot of Searching, Testing, work ahead of him.
That's as far as I'm going. Don't Test the Coil Improperly and Burn it out!!
MJ
I have found that the Ford dual point distributors that use the same design points cam (Boss 302, 351CJ, 429 CJ) for some reason unknown to me seem to wear on the internal portion of the points cam. (the pivot).
Now I only work on things that pertain to me. I am not a professional restoration shop so it seems obvious that my situations may not be common across the board.
In order to maintain accurate point settings throughout the distributors rotation, the clearance on the distributors drive shaft and the points cam need to be accurate.
IF the play between the shaft is greater then maybe .0005". the settings on the points will be inaccurate.
If the cam is wobbling .0005", the then setting on the points will be wobbling at least .001".
Now here is the point, take the cap off the distributor and push the points cam. If you feel it wobble, then it needs to be dealt with.
I have found the cam worn internally as much as .0050". That means that your point setting is off .0100". With that you will not get anything like an accurate coil firing because the points are going to be grounding all of the time.
Now I know that you posted that you set the dwell, but I don't know the method that you have used so there is still a possibility that you have excessive wear in the cam.
Now if after checking this for wobble, you find that it is there you have to deal with this. If you feel it, it is more then .0010".
Those cams have not been available as service parts for decades from Ford and virtually anyone else in the aftermarket.
The three engines mentioned all use vacuum advance along with the dual points and as such those cams are unique and not the same as in the earlier 289hp, 427's, etc.
There are three variations of them depending on the notches in them for the mechanical advance the specific engine uses. As far as I know, three different advances for three different engine families.
So the choices are two. Replace the cam with one that is not worn, if you can find one,  or repair the one that you have by knurling  and reaming it.
As it turns out the dimension is 5/16" and that is an easy knurler to come up with and the reamers are common as well, in both the standard size of .3125" or +.0001 or +.0002, etc.
It is something that you can easily do yourself with these hand tools. Nothing that NASA needs to do for you?
So if you have noticeable wobble in the cam, and you still won't fire with the dual point Ford distributor, investigate for excessive wear internally in the distributor.
Is this a completely bizarre thing to look for? Absolutely, but to some, the situation is right in front of them and completely invisible.
If you have already checked for this and you have no wobble, ignore this and go back and finish the video game you were playing. Just think of this post as an eccentric old guy substituting posting here for therapy.
I am sometimes concerned with this as well. Prefrontal labotomy keeps coming up in a reoccurring dream and I keep escaping the nurse that wants to stick me with that big hypo that she says will calm me down!
Thank you all so much for the help and advice. Looks like this guy definitely has a lot to do. I just hope I don't need to send her to the hospital..
panteradoug - that was great! Technically, I could have made a mistake during the tune-up since I did indeed have brain surgery last year. Something about removing a mass. They might have taken too much as I don't have much to spare.. :-)
I'll provide updates. (For your comic relief if nothing else.)
William
...It looks as if the Plug was NOT Grounded during the Testing! That is Exactly HOW You Destroy a Coil!! I Did Warn You!!
With NO Ground, the High Voltage 'Seeks' a Ground with-in the Coil, and Finds it To the Primary Wiring! This 'Burns' a Permanent 'Path' through the Windings that will Forever be a Short in the Coil! The Coil becomes Junk! The HIGH VOLTAGE Has to 'DUMP' somewhere...and it's To the Primary Ground, INSIDE the Coil!!  FWIW
...Good Spark! Coil Good! Go For IT!! See If the Inside of the Dist. Cap is 'Carboned-Up'.
Oh, wait, the Cap and Rotor is New?
If You need to Re-Gap the Points...I always went with .017". A Great 'Feeler Gage' is the Carboard of a Matchbook Cover. Dual Points May be Different.
...But I see what Doug means...the Oil Fouled Plug, has Clearly NOT Been Firing, OR All of that 'Crud' would have Been BLASTED Away! Plugs are 'Self Cleaning' in That Way. The Plug in the Other Photo, that was 'Dry' and Close to the Correct Color, Looked as if It Had Been Firing 'Normally'! 'Anti-Fouling', One Other Good Benefit of a Dual Fire System. Excepting for Double the 'Burn' Wear at the Spark Gap Points.
...The Gentlemen who suggested that the Distributor could be 180 Degrees OFF Timing...are RIGHT ON, Correct!!! To Make absolutely 100% Sure I'm at 'The Top' of the Compression Stroke of the Number 1 Cylinder. I stick My Finger in the Spark Plug hole, while I Remote Crank the Starter. Ignition OFF Ofcourse. And then Confirm, and Align at the Balancer Timing Marks! Then, I Set the Distributor and Plug Wires. The Rotor Turns CCW.
...One thing more I'd like to point out about Spark Plugs!
1-2 Out Of 100 will NOT Fire. Not Just because they are Fouled, but because they are Broken Inside. Came-on when 'they' started producing the 'Resister' Plug. The Inside Conductor or Resister is just Not conducting.
It would be a Advantage to all of us if we did the 'Spark' Test, as Demonstrated previously, To all sets of Spark Plugs, before Installing them. Making sure they can even Pass through a Spark.
In the 56 Years I have Been 'Hot Rodding' I have discovered Exactly (2) Non-Functioning Plugs!! How many were Not-Knowingly, replaced as In a Tune Up...I'll Never Know! May have been fouled or even intermittent.
The Above Oil-Fouled Plug in the Photo, may Not have been Fouled by the Oil, but Fouled from Not Firing!
Food for thought!
Thank you for alll the spark plug info! I’ll definitely do all the above. I still don’t see how the cap can be put in backwards? Is has a notch and The 1 is on the front (facing the rear if the car) and wires start there and follow the sequence around.
Regardless, I decided to start by removing the carburetor and clean it. I’ve been having backfires so the jets may be getting clogged.
IMG_1304IMG_1300IMG_1303I’ve had the tuning kit since I bought the car but had been afraid to use it… 😬
Here we go!!😁😁
Images (3)
  • IMG_1304
  • IMG_1300
  • IMG_1303
"I still don’t see how the cap can be put in backwards? Is has a notch and The 1 is on the front (facing the rear if the car) and wires start there and follow the sequence"
You are correct that there is a notch for the cap and that the number 1 tower is marked.
However, it takes TWO revolutions of the crankshaft to equal ONE revolution of the distributor shaft. You must rotate the crankshaft to TDC on the COMPRESSION stroke, then install the distributor with the rotor pointing to the number one position (on the cap).
John
Seriously?!? I'm willing to bet this is the issue. I wish I had asked this the first time it was brought up. I must have got lucky the other times I did the tune up.
I'm half tempted to put the carburetor back in just to see. I had removed the bulkhead and cover last weekend to prepare for the worst.
If nothing else, I hope everyone has been getting a kick out of watching me walk around in the dark... :-)
"So "technically" if I were to rotate the crankshaft 360 degrees I would be on the right side of the cycle?"
Yes, If the crankshaft wasn't on the compression stroke.
Pull the #1 spark plug and rotate the crankshaft until it is on the compression stroke (you will feel air rushing out of the spark plug hole as the piston approaches TDC).  Rotate the crankshaft just enough to align the timing marks on the balancer with the timing pointer.
Next, look to see where the distributor rotor is pointing.  If it is pointing opposite the #1 tower on the distributor cap, then your distributor was installed 180° out of sync.
John
@transsami posted:
But was the distributor ever removed? I though just the cap was replaced.
- Sami
That’s correct. I only replaced the cap, rotor, points and wires, so not sure why the distributor or the balancer would have changed. It really makes sense that I’m on the wrong cycle.
Also. I believe the reason the car was becoming hard to start was because when I removed the fuel filter, some black debris came out of the inlet. Since the hoses were brand new when I bought the car (18 years ago 🤣) the ethanol, I understand, could wear out old fuel lines.
