I'm trying to remove an ignition switch from the steering column. The parts book shows the ignition switch collar bolted onto the steering column but mine is mounted with what almost looks like a rivet or a stud with a press on fitting instead of a nut. Can anyone tell me how to remove this without damaging the unit? Thanks in advance.
  • ignition
You have to remove this like you would remove a riveted on ball join. You drill a hole through the middle with something like a 3/16 or a 1/4" diameter drill and take a cold chisel and chop off the rivet head.
This is a "tamper proof" installation on the later cars. Earlier cars has "one way screws".
You can probably step up the size of the drill bit also until the head falls off.
As I rember, the heads are hinda' thick. Take the entire column out and do it in a vise on the bench.
It appears to be the earlier Mercury Capri design, where the head shears off after proper torque is applied. It CAN be removed by using a nail set punch and a ball peen hammer. Set the punch at approximately a 45 degree angle on the edge of the head, positioning the punch so that as you hammer on it, the screw would be driven counter-clockwise. The head IS soft enough that the edge of the punch will dig in and allow you to "push" the screw to unscrew it.....
Rick "Had A Bazillion Capris Before His Pantera" PanteraHunter
Originally posted by LF - TP 2511:
Here's a photo of what you are dealing with.
Drill center hole and easy out, as Rick just wrote.
Sloting the head with a Dremel cut off disk and unscrewing will leave you with a more usable bolt.
And yup, early Mark I pre-face lift Capri column
Thanks for the picture Larry, I never saw one of these bolts.
