It looks like I'm the first.
My car came with an MSD 8350 with the vacuum advanced locked out (for some reason - not that the car was ever tuned or dyno'd).
I like vacuum advance and was going to put it back in but, as I did some research, I ran across these guys:
https://progressionignition.com/
They seem to be a new player but this seems WAY better than fighting with advance springs, stop posts and vacuum valves.
Looks pretty impressive!
https://www.youtube.com/embed/neiyDK0wQRM
AND now I don't have to try to get the f****** snap ring off the MSD to replace the vacuum can.
Will let you guys know how it goes.
Jtpantera, I suffered exactly that problem with an Accel dual sync distributor. The engine suddenly began running rough and the problem turned out to be the circuit board in the dual sync distributor. Apparently, it was a common problem. Luckily, my dealer had spares in stock.
My long term solution was to ditch the distributor and run distributorless, with separate cam and crank position sensors. For the cam sync signal, I used a Price Motorsport Cam Synchronizer, which uses an OEM Ford Hall Effect sensor. For the crank signal, I used a GM style 60-2 tooth trigger wheel and Hall Effect sensor.
I have one in my 393C but not in a Pantera, 10.2:1 with aussi heads, RPM airbag and a roller cam setup and I was done with the "run of the mill" distributors not working well with the setup. Dropped it in, set base timing and had my son driving while I made  adjustments with my tablet or phone. It's slick and I'm  pretty happy with it. I'm sure it's not cammed correctly and the other distributors I just couldn't get dialed in, was either pinging or sluggish beforehand. Only a few more bucks over a  MSD.
@jmardy posted:
I ran across these guys: https://progressionignition.com/
They seem to be a new player but this seems WAY better than fighting with advance springs, stop posts and vacuum valves. Looks pretty impressive!
So, how'd it work out?  "Inquiring minds want to know!"
  1. Does it fit under the stock Pantera engine cover/screen?
  2. How tall is it from the top of the cap to the ring that seats on the block?
@jmardy posted:
Hey Doug, I guess I got lucky, I installed it in place of the MSD 8350 and did nothing else and tach worked fine. So whatever was done by the PO's shop to make the MSD work.
Being able to easily set the redline is nice too, in case you let one of your friends drive the car who are, well, you know. :D
Do you mean that you would consider shutting it off from a distance?
I have an MSD ignition (distributor, box, and coil) and it works well.  It was easy to install and configure, and it has worked flawlessly.  This Progression ignition adds several features that I do not have and can benefit from.  They are:
- Timing retard at startup.  My car is hard to start when the engine is hot.
- Rev limiter.  My MSD box is older and does not have this.
- Ability to change the advance curve with software.  MSD can do this with springs, weights, bushings.  I do not mess with my current setup because it is adequate.  Changing it is another project.
MSD provides solutions to all of the above.  But doing it with MSD is complicated and somewhat pricy.
I am considering changing to the Progression ignition from a practicality perspective.  Perhaps it is time to move on.
Hi @Stevebuchanan,
Are you using this distributor with EFI or carburetor?
I'm installing the Sniper 2 EFI while the engine is getting sleeved and was planning to stay with my MSD 8350, but this distributor looks interesting.
I won't be able to control timing with the Sniper 2 so I assume the Progression distributor would be helpful even with EFI?
Thanks,
John
#3590
Hi John,
I am using it in my 74 Euro Pantera with a Holley 750 vacuum secondary.  It needs input from the intake manifold for vacuum reading.  The Progression Ignition distributor does the rest.  Obviously, t knows RPMs because it mates with the cam.  It seems like it would work with your EFI in this case.
My car had an MSD 8477 prior to the Progression Ignition and it was an amazing upgrade.  Like I wrote before, no springs, weights, or vacuum canister.  You program it on your phone.
Regards, Steve
Images (2)
  • mceclip0
  • mceclip1
