I tried posting this before.
http://performance.ford.com/se...t-busch-pantera.html
quote:but the side cut in the decklid...ugh.
quote:Would be interesting to see what transaxle they used, doesn't look like a ZF
quote:Originally posted by Push1267:quote:but the side cut in the decklid...ugh.
Funny, I was about to comment that I liked it. For once an air intake that doesn't upset the lines of the car too much
quote:Originally posted by ItalFord:
I for one am really interested in the transaxle they used for this car. Sequential clutch less gear changes cool. Does anyone have any info on this?
quote:Originally posted by PanteraDoug:quote:Originally posted by ItalFord:
http://holinger.com.au/showroom/mft
520 ft-lb torque limit.
quote:Originally posted by r mccall:quote:Originally posted by PanteraDoug:quote:Originally posted by ItalFord:
Torque rating for 24 hour endurance events is 700Nm (520ft.lb). This is not a failure rating but an indication of life expectancy in long events with 100% reliability.
quote:Originally posted by Marlin Jack:
...Gentlemen, hate to 'Split Hairs' here.
But in the name of Accuracy:
Torque Wrench= Ft/Lbs = Foot Pounds
Engine Torque= Lb/Ft = Pound Feet
Thank You!
quote:Frankly, why even do a ring and pinion in your ZF? Those are $3000. Sell your ZF. Then buy the RBT from Loyd at RBT?
quote:Originally posted by ehpantera:
My personal feelings regarding a ram air feed into the induction system,is that while it is a nice study, the reality is that very few Pantera owners will drive their cars in such a way a to benefit from such mods. Most of the benefit will come to those who push the engine to higher RPM'S and especially in 4th and 5th gear as you will spend proportionally more time in these gears.
Mark
quote:Originally posted by comp2:
I would think it would be easy to data log airflow into a scoop and temp along with speed. I would look at using a mass airflow sensor to read the air. It wouldn't be too hard to make a micro controller circuit which could log this on an SD card.
quote:Originally posted by comp2:...It wouldn't be too hard to make a micro controller circuit which could log this on an SD card.
quote:Originally posted by Bosswrench:
I've been told some Bonneville runners don't like direct connection ram-air to carbs. One was quoted as saying..." it became confusing to sort out proper jetting with ram air hooked up...."
JFFR (and the Kurt Bush Pantera) uses EFI which likely operates under different rules.
quote:Originally posted by pantera chris:
Jack ,you have hit on it, ramming air into a carb directly changes the fuel to air mix, it is also problematic going one way with a slight breeze then with the breeze, the solution is to baffle the air from hammering into the carb.
