My 1974 Euro Pantera has had a noisy valve train since I got it two or three years ago.  It has a hydraulic roller cam, roller rockers, and guide plates for the push rods.  Soon after getting the car I put in a new set of Comp Cam lifters when I found debris (oil filer element?) in two of lifter oil inlets.  Since then I have adjusted the lifter preload numerous times in an effort to quiet down the valve train without complete success.  I finally tried Liqui Moly for hydraulic lifters and it worked.  Because I have a high capacity oil pan it took two bottles of Liqui Moly.  The noisy lifter sounds were immediately reduced and nearly eliminated.  If you have a lot of lifter noise it may be worth a try.
20004_Hydrost____el_Additiv_300ml_d203
  • 20004_Hydrost____el_Additiv_300ml_d203
