...For ALL.
Look-Up 'Link-Belt'. You make the Belt Length Yourself. Assembled using your hands, No Tools needed. No tools needed to install...just make it to size, the Belt will Stretch Over the Largest Pulley without having to loosen anything. 'Crank' the Engine to stretch the Belt onto the Larger Pulley. Carry one of proper width in the glove box. Can be used as in a Emergency and is designed to be used Permanently! They run smother and quiet. They run in One direction only! The 'Tail' points Opposite to the Direction of Travel.
MJ
