I read this topic, and wonder if somebody would advice me on the "best" exhaust combo (no 180 headers) for my gr4 project please
Holley Dominator, 351cu, single carb, 4v heads, magnum 294 comp cams
Best regards
Philippe
Hall Pantera, Paramount California
If you want the best performing Pantera headers money can buy contact Pat Mical:
Performance Automotive Technology, Tyngsboro Massachusetts
A 3" collector is necessary to make the headers scavenge. That is one of the benefits of fabricated tube headers.
It would be interesting to add a thread to this on what the decibel level readings are that everyone is getting from their systems, EVEN STOCK!
With the availability of the free sound level apps for smart phones, this is a piece of cake.
At this point just saying, stock, a little louder, etc, can be put into numbers so that EVERYONE has a reference to what can and can not be done sound wise?
I'm getting flack from people who are just looking at the exhausts and telling me they are illegal. They haven't even heard them run.
I don't know where that is coming from since I keep looking high and low and can't find one violation in the statutes.
It might simply be that people don't believe this is a production '73 model year car? They want to know where the catalytic converters and the air pump is?
Anyone out there that has experienced being stopped for "roadside examination" on their cars like the CHiPs still do occasionally in CA?
anybody to identify my exhaust please ?
regards
Philippe
They maybe original factory gts headers by the original vendor? They are definitely tri-y's.
As such they are giving away about 30hp on the top end but provide more low end torque off of idle.
They work best on a basically stock engine. They do not work well on a high performance/race engine.
quote:Anyone out there that has experienced being stopped for "roadside examination" on their cars like the CHiPs still do occasionally in CA?
Doug, I haven't had any problems with CHP in So.Cal. I drive both my 67 mustangs and pantera on weekends mostly. No issues what so ever with the CHP. The BAR does set up a road side random smog inspection complete with dyno but I have read that its voluntary.
I suspect it will get more and more difficult to drive these cars as the years pass.
https://www.youtube.com/watch?v=nic5OQCFCus
tail pipes are about 2-3/8" OD.
Wilkinson also sold (as a set) stainless steel headers and mufflers. These were also available in mild steel. Primaries are 45mm (1.77"); exhaust pipes are 60mm (2.362"); tail pipes (tips) are 3".
I don't know what he is currently selling.
John
quote:How is the quality of his stainless exhaust?
It seems to be ok. As with any polished SS exhaust, it will require occasional cleaning.
As a reminder, always make sure that the flange is FLAT before bolting the headers to the cyl head.
John
I have tentative plans to make a custom stepped stainless header with a 3" collector and a 2.75" choke. Stainless Headers built a set for one of my other cars and did a great job.
quote:Originally posted by "72 GTS:
Hello
regards
Philippe
C-302 B heads
quote:Originally posted by pantera chris:quote:Originally posted by "72 GTS:
Hello
regards
Philippe
C-302 B heads
Maybe, but I don't think so? I have a set of those here.
This is what the mounting flange looks like.
The important thing is the shape. Those generally show the obstructions they need to clear.
you are right Doug, but I was basing my conclusion on the mounting holes, it is obvious they leaked. I think they may have started as 4V.quote:Originally posted by PanteraDoug:quote:Originally posted by pantera chris:quote:Originally posted by "72 GTS:
Hello
regards
Philippe
C-302 B heads
I don't recognize the application of those headers? What are they for?
Those are F355 headers. They replicated the factory headers in 321 s/s. They then modified the factory clamshell that covers these headers since the primary pipes that they used were slightly bigger than OEM.
quote:Originally posted by pantera chris:you are right Doug, but I was basing my conclusion on the mounting holes, it is obvious they leaked. I think they may have started as 4V.quote:Originally posted by PanteraDoug:quote:Originally posted by pantera chris:quote:Originally posted by "72 GTS:
Hello
regards
Philippe
C-302 B heads
VERY LITTLE bolts up to those heads. Headers would not without adapeter plates, but why bother? In a Pantera, just get the right headers.
Stainless headers are absolutely beautiful new but I like the ceramic coated steel better.
Just take some Windex and wipe them down. If you want to go crazy, buff them with Mothers wheel polish.
The ceramic maybe will get a little dull if you are running lean and super heating them but even then they wind up looking like "mill polish" stainless.
i`m planning to wrap my Hall headers (as in PanteraDoug`s post) with basalt fibre to reduce heat in my engine bay.
Especcially the pipe coming very close to the oil filter concerns me a bit.
Does anyone have experience, how much and what material to use?
Best regards,
Philipp
I have heard the heat-wraps can cbsirb water and cause corrosion...
quote:Originally posted by Rocky:
Do you ever drive the car in the rain?
...I Second this. I have been told by more than one Experienced Source, that 'Wrapping' Header Tubes....Yes, Keeps Some Heat from concentrating in the Engine Bay, 'It' also keeps the Header, itself, from 'Cooling', Therefore Accelerating Disintegration of the Steel. Plus, It Looks Like Crap, In My Opinion. So Go For It!
If Your worried about the Oil Filter taking Heat, change to a Remote Filter System. Also think about the Fuel System winding around/near the Header.
Mike
I think I am going to stick with the under the car approach. The improved sound would be the major advantage for me on the 180 degree route, but I really like how easy it is to get to the engine, plugs, etc. I don't think I want to give that up for sound.
Has anyone encountered a "DRONE", 1800 TO 2200 RPM? IF SO HOW DID YOU SOLVE IT?
Dick Ruzzin
Dear Dick,
Ah, yes, the infamous Pantera drone. In your case, a Mangusta drone? Please check this tech article from the Great Lakes Panteras website tech session. I found the approach to be unique. I followed up with Gerry and found about a handful of Pantera owners in their circle that had done the mod and they noted less "boom" and , in one case, a dyno proven increase in power. If Gerry's theory that the boom is due to a sonic Helmholtz effect is correct, then if it occurs in a Pantera, it should also occur in a Mangusta. There being so few Mangustas, I haven't heard of the boom phenomenon with them, but I bet it is there.
http://www.greatlakespantera.c...r%20Modification.pdf
Warmest regards, Chuck Engles
I have a friend who worked at Chrysler in the carburetion and exhaust lab and he says he can find it. He is in Florida nowThanks for the advice.Dick Ruzzin
Dear Dick,
If I understand Gerry Romack's Helmholtz Effect theory, then the packing would not have changed the symmetry of the "acoustic chambers" of the mufflers. The symmetry with the equal pulsing of both exhausts creates at a certain rpm/frequency of pulses the reasonance that reinforces the other. That range of rpms that generates the reinforcing waves creates bigger waves which result in the notorious boom.
The Romack fix alters the acoustic chamber so that they are no longer symmetric and that, apparently, disrupts the re-inforcing sound waves and reduces the boom. The asymmetric mufflers have new resonance at non-complimentary rpms and therefore do not reinforce each other to produce the boom.
In Gerry's case he did pack the muffler with steel wool packing at the same time as he did the mod. He reports that his exhaust sound was very much reduced. Then he took it on a chassis dyno and unintentionally blew out the packing. The exhaust level did increase somewhat, but the Pantera boom remained greatly reduced. Also, if I recall correctly, that dyno test resulted in a measured *increase* in HP over an earlier test with the normal muffler configuration.
I intend to modify my GTS mufflers this year.
