I'm still working on getting my AC working for the trip down to Monterey. My current task is to replace the expansion valve. The coil on the valve is attached to a clip that is attached to the evaporator pipe.
My question is how does that clip come off....and then go back on? And how is the capillary coil attached to the clip. It looks like it might be soldered but I'm not sure.
thanx,
John
#2647
The method of the sencing bulb is to transfer temp to the bulb and back to the capliary tube and to the TXV. The bulb .. I would not solder to the pipe. You can use some metalic heat transfer compound and then wrap it with black sticky thermal tape. Both cost maybe $10 at any HVAC supply. Its very important to tranfer the temp.
To answer your question I'm not 100% sure about the clip on the Pantera as I have not taken mine apart yet but I'm in the process of starting. But the two pieces should be touching.
Ron
sorry not 100% sure what it looks like. If at the end of the Cap tube there is a bulb .. thats what needs to touch .. the cap tube usually is just like and extension cord so the TXV can be used in multiple apllications. If there is no Bulb then the cap tube is it .. put a little heat trans compound on the pipe wrap it around and wrap it heavy with the black tape. Just a precaution .. are you brazing the TXV or soldering it in place. make sure you use a wet rag or there are other heat shielding methods to prevent damage to the new TXV. My advise is brazing it with 15% silver ... but make sure to use a fine torch tip.
Ron
