Nothing wrong with either. During reassembly of 2511 I changed everything to silicone hoses using the correct non-gouging hose clamps.
as has been previously mentioned by others there is a tendency for silicone hoses to weep coolant, and clamps should be re-tightened after some initial use. Others have suggested scuffing the inside of silicone hoses with a coarse sandpaper to enhance sealing
I removed the OEM heater tubes and used two 10 foot pieces of 5/8 inch silicone hose; very easy to work with
I had previously relocated my coolant bottles using the billet bracket sold by vendors and found piping angles had changed. I replumbed using silicone elbows, which are offered in many different angles and sizes
