Looking Nice
Kjeld
quote:Originally posted by 2112:
Are you coming over the top with your exhaust?
quote:Originally posted by agustaboy:
Set in place. Did this alone so I'm a bit exhausted right now.
quote:Originally posted by PanteraTurbo:
When I originally put it in I had to drop it into the bay till the engine was sitting above the fender wells on a rolling cart. I then disconnected the hoist and rolled the engine forward into position. Then I lifted the car up on the vehicle hoist. I didnt have the bellhousing at the time.
quote:Originally posted by agustaboy:quote:Originally posted by PanteraTurbo:
Having a bare block and heads to work with has really made it easy to this point.
Trans bolted to bellhousing and block, no fly wheel, no clutch and no engine internals.
Ive had the motor/Trans in and out of the car about 6 times now. Solo! Putting the fully dressed motor in was a real work out. Phew!!!![]()
quote:Originally posted by 1Rocketship:
NICE WORK!...Are you going to weld CO2 bungs for tuning purposes?...Mark
I am glad one of us is making progress. I have only managed to make my project larger and larger. Keep up the good work.
quote:Originally posted by PanteraDoug:
Nice but I hate infinitely adjustable linkages. You are going to be there FOREVER!
quote:Originally posted by David_Nunn:
Who are you going to use to set it up and do the dyno tuning? If Borla recommended someone I'm curious to hear who it was.
It's very nice the way they've eliminated the "above manifold" vacuum lines and MAP sensor (and IAC) plenum by casting a plenum into the underside of the manifold.
quote:Originally posted by Hustler:
Where at in NW Agustaboy? Nice job on the mod motor swap.
Blaine,
Holley says they are in the process of developing VCT outputs for the Dominator. They don't have an ETA though.
Very nice intake! That wasnt cheap...
Obscene! Filthy!
quote:Originally posted by agustaboy:quote:Originally posted by PanteraDoug:
Obscene! Filthy!
I like to think of it as.
"Naughty but Nice."
OK Off to the engine tuner for a dyno run.
Evan, "glitches"? Interface issues? It sounds to me like you need help from someone who has specific expertise with I.R. intakes. Even better, someone who also knows Holley EFI systems. If your problem doesn't get resolved quickly and to your satisfaction, call Holley directly and ask to be referred to one of their dealers who specializes in Ford V-8's and I.R. intakes. I'd be nervous that Borla referred you to MMR because they buy lots of Borla stuff; not because MMR knows Holley EFI and I.R. intake systems better than anyone else.
Very nice.
This is my Motor
Interesting "Flat Plane" crank info
A friend and fellow Pantera owner who builds and races Panteras has installed several Coyote engines in Panteras. Fantastic fit, seemingly easy conversion if you know how. Maybe you know him, if not, name is Ron McCall out of Maryland. possibly he can provide additional advice to anyone that's interested, or build one for you. Try rfmaccall@comcast.net. The image is of the car he races. 200 mph car.
I'm curious to hear how the Voodoo motor feels in the Pantera. I know it will sound incredible! You may want to look into adapting the Shelby GT350's "Voodoo" engine mounts. I understand they are quite a bit different than the Mustang's engine mounts, as they need to contain the vibration that's inherent in the Voodoo motor.
How is your Coyote engine swap progressing?
Oh wow! That is amazing! Can’t wait to see it all together
How did you create clearance for the cam advance actuators in the firewall?
MADE A CUSTOM SET OF MOUNTS AND MOVED EVERYTHING BACK 1.5in
