Where is our update!! We are all excitedly waiting.
![Confused](/static/images/graemlins/icon_confused.gif)
quote:Originally posted by David_Nunn:
Evan, "glitches"? Interface issues? It sounds to me like you need help from someone who has specific expertise with I.R. intakes. Even better, someone who also knows Holley EFI systems. If your problem doesn't get resolved quickly and to your satisfaction, call Holley directly and ask to be referred to one of their dealers who specializes in Ford V-8's and I.R. intakes. I'd be nervous that Borla referred you to MMR because they buy lots of Borla stuff; not because MMR knows Holley EFI and I.R. intake systems better than anyone else.
The engine is just down the street from Holley and Borla.
The people working through the issues are reps from Holley and Borla. This system is the newest fuel management system from holley. It will be debuted this year at SEMA
I have serial #0000001
I hate being the guinea pig.
![Party](http://i61.photobucket.com/albums/h51/gp_fillmore/Pantera%20International%20Car%20Club/Party%20Smiley_zpsogmubx42.gif~original)
Update???
P.M. Send.
Kjeld Pedersen
Denmark
Hmmmm Good question.
The engine compartment is stock, sound deadening splattered everywhere, ugly spot welds etc. etc.....
Decided to try something other than scraping it all clean and painting.
Trying for the Engine compartment to have a
fabricated race car look.
Did you get the P.M. i send you?
Kjeld.
TALKED WITH PANTERAS BY WILLKINSON AND HE DIRECTED ME TO CENTERFORCE FOR A CLUTCH/PRESSURE PLATE AND FLYWHEEL COMBINATION.
HE ALSO VERIFIED THAT IF YOU MOVE THE TRANS FROM THE STOCK POSITION (1.5in REARWARD) THAT CHANGING TO 911
CV SHAFTS IS A GOOD IDEA SO I HAVE A SET ON ORDER FROM SCOTT AT SACC RESTORATIONS.
THE CLUTCH PRESSURE PLATE AND FLYWHEEL ARE COMING FROM SUMITT.
CENTERFORCE PT#
Flywheel part# 700205
Pressure plate, disc part# DF800075
THESE STATE THAT THEY ARE FOR A 4.6 BUT WILL ALSO BOLT UP TO THE 5.0 COYOTE.
Will it works fine with the engine ? Thanks
sounds like an interesting project. Post some details and some pictures. I`m sure we can all learn something from you.
Liebe Grüße aus Düsseldorf
"Holley EFI Coyote Twin Independent Variable Cam Timing Control unlocks the full power potential of high-revving 2011-14 Ford Coyote engines. Ideal for both crate engines and/or used Coyotes with locked cams, they're compatible with both Holley HP and Dominator EFI. They feature integrated stock cam position tables that eliminate tuning guesswork and deliver optimal driveability and maximum power right out of the box. At 3,700 RPM, they unleash more than 90 additional foot-pounds of torque. The main harnesses are terminated with ford TPS and IAC connectors that make it easy to convert from a drive-by-wire throttle body to a manual throttle body, and four built-in diagnostic LEDs make troubleshooting a snap if there's a cam- or crank-sensor failure.
Holley EFI Plug and Play Coyote Ti-VCT Control Module main harnesses include a power tap connector and grounds for adding additional sensors or actuators and CAN bus communication for the Holley EFI ECU for high speed data transfer and diagnostics. Also available are a plug-and-play main harness for 2011-14 Coyote engines with stock cam shafts and stock coils (part number 558-110) and a plug-and-play main harness for stock cams and Holley EFI coils (part number 558-122). If an external map sensor is required, use the available 2-bar MAP sensor (part number 538-13) ."
Very nice.
This is my Motor
Interesting "Flat Plane" crank info
A friend and fellow Pantera owner who builds and races Panteras has installed several Coyote engines in Panteras. Fantastic fit, seemingly easy conversion if you know how. Maybe you know him, if not, name is Ron McCall out of Maryland. possibly he can provide additional advice to anyone that's interested, or build one for you. Try rfmaccall@comcast.net. The image is of the car he races. 200 mph car.
I'm curious to hear how the Voodoo motor feels in the Pantera. I know it will sound incredible! You may want to look into adapting the Shelby GT350's "Voodoo" engine mounts. I understand they are quite a bit different than the Mustang's engine mounts, as they need to contain the vibration that's inherent in the Voodoo motor.
How is your Coyote engine swap progressing?
Oh wow! That is amazing! Can’t wait to see it all together
How did you create clearance for the cam advance actuators in the firewall?
MADE A CUSTOM SET OF MOUNTS AND MOVED EVERYTHING BACK 1.5in
