Any idear about Hav much lighter the Engine are than the cleveland?
Les kg more speed.
![Thumbs Up!](http://i61.photobucket.com/albums/h51/gp_fillmore/ThumbsUpSmiley_zpsf7f93e49.gif)
Kjeld
quote:Originally posted by Husker:
You must have an inside line. The cable conversion isn't on his website (yet??).
quote:Originally posted by 2112:
Are you coming over the top with your exhaust?
quote:Originally posted by agustaboy:
Set in place. Did this alone so I'm a bit exhausted right now.
quote:Originally posted by PanteraTurbo:
When I originally put it in I had to drop it into the bay till the engine was sitting above the fender wells on a rolling cart. I then disconnected the hoist and rolled the engine forward into position. Then I lifted the car up on the vehicle hoist. I didnt have the bellhousing at the time.
quote:Originally posted by agustaboy:quote:Originally posted by PanteraTurbo:
Having a bare block and heads to work with has really made it easy to this point.
Trans bolted to bellhousing and block, no fly wheel, no clutch and no engine internals.
Ive had the motor/Trans in and out of the car about 6 times now. Solo! Putting the fully dressed motor in was a real work out. Phew!!!![]()
