The Support Group:
“EPS anonymous” : my name is Roland and I’m installing a electric Powersteering unit in my Pantera… 😳😳😳🤓😱😱🤔🤢
…. don’t judge me…!!   LOL 😂
I think it would be a great idea! I haven’t found any real information,  aside from what the manufactures provide, of people bolting Powersteering in Panteras..
that was one of the reasons I started this thread! it would’ve been a hell of a lot easier if I would’ve known what I know now! there’s no reason everybody has to go through the whole learning curve!
I definitely recommend buying a super short 90° angle drill! it has to fit with the drill on it in a space of 97 mm! Changing to studs in the front, measuring the distance between steering tube and dashboard before you take the original out…. All that would take a lot of work   ( and guess work) out of it!
Today. I fixed my lower steering tube (big thanks to my 15-year-old daughter, who helped me a lot getting the thing back in),  the brake light switch that was installed on the brake pedal stop and cut the wiring out and re-soldered (once again under the dash but behind the pedals ) it to go to the brake pressure sensor in the front, got rid of a few wires under the dashboard, which made no sense and don’t belong there , found a wire I do not know where it goes to , rerouted the wiring harness for the ignition switch , Ceramic coated my wheels, retightened and all my brake fittings… and the day is not over yet!
IMG_0948
  • IMG_0948
Of course, far be it from me to make suggestions, but….
I have seen dashboards where they have “connectorized” all the dash, so if they have to remove it in the future…. it’s a snap!
Do you think that’s worth considering?
(I have never removed my dash….  I’m too scared of the “while I’m in here…” syndrome!)
@rocky posted:
The factory wiring is like that mostly…
the things that made it very interesting are the modifications done by previous experts!!! Crisscross jungle.. cut cut cut cut and I figure it out and do it correctly!
you have multi plugs from the factory for
turn-signal switch
speedo
tach
gauges (I think I had someone adding wires that didn’t plug
emergency flasher
didn’t see multi plug for
wiper switch
& what’s the switch next to it??
the 2 dash panel lights
blower motor
the biggest biatch was the heater controller - that guy made me angry.. its sandwiched onto the center console, 2 7mm nuts and some grove hook thing on the right side
otherwise not bad… a few identical spacer, 3 I think spacing the dash from the back!
Start taking speedo, and Tach out little flash light and off you go…
IMG_1080IMG_1079IMG_1078
Images (3)
  • IMG_1080
  • IMG_1079
  • IMG_1078
@rocky posted:
For the number of times you're going to remove the dash, it's probably not worth the time and effort to put everything on quick-connects. I do think it's a good idea to do it to the gauge panel because you are much more likely to be removing that from time to time. In order to do it, you must replace the ammeter with a voltmeter, which isn't a bad idea anyway.
Gauge Panel Wiring
100_4051
Images (2)
  • Gauge Panel Wiring
  • 100_4051
@davidnunn posted:
Gauge Panel Wiring
100_4051
Agree!! The majority does have multiplugs  anyway! That gauge panel is a pain!
I need to point out that the mounting of the steering column is MEGA rigged!!
I contribute that to the @davidnunn upgrade with a tube welded in on the rear mounting bracket!!! There is zero give in any way!!! I put my weight on it in every direction.. it is absolutely solid!
The nut to hold the thru bolt (110mm) needed to be kissed with the grinder (no room for washer)  to make it thinner to fit! Zoom in to see the perfect fit of bracket and motor…  you see the thin light hairline of a gap..IMG_1197
Loctite on the nut!!
  • IMG_1197
It’s been a little while, but today I hooked up the Powersteering for the first time after I figured out the problems in my electric wiring!
I choose to use the speed sensor that mountains between the speedometer and the speed cable. (there is a second option that comes in the Kit Which touches to the 90° angle drive on the transmission and you run the wire all the way forward to the dashboard! I was not very happy with running the wire right over the driveshaft within a quarter of an inch, it attaches to the 90° angle drive on the transmission and you run the wire all the way forward to the dashboard! I was not very happy with running the wire right over there driveshaft within a quarter of an inch of it) From this on the speedo Mounted speed sensor comes one white plug that attaches to a short wiring harness. On this Wiring harness Is a plug that bolts into the control unit that’s under the power steering motor, red cable for a battery plus, a thin, red cable for ignition plus, a black cable bolt onto ground and a little black box with a tab on it.
I also connected the Battery plus wire For the posting to the wire that runs to the ignition, connected the ground cable to the right Bolt, who holds the steering shaft to the dashboard, and also attached the small box with a microchip in it (Very unqualified guess) By Drilling a hole on their steering column bracket and bolted it on! Only one wire missing now..
just sitting in the shop… No engine running turning the Steering wheel… And it was heavy, uncomfortably heavy to me and then I connected the last wire 15… Ignition +
And it took about one and a half seconds and you hear the click..  turning the steering wheel like you have 155’s on the front No sound to be heard from the power steering no humming, no  buzzing no anything…
very very interesting!
IMG_1913
It’s not like Powersteering I am used to, which are a different approach to servo Powersteering. This feels like it just got easier to turn not taking all the workload off. Me just makes it acceptable, very acceptable! If you take the new bronco or a Dodge Durango r/t or Hummer H2, those are one finger turning steering wheels not being in motion this is NOT a one finger turning Steering wheel! It’s not overpowering at all it just feels normal! Obviously, I have to say something good about it because i spent quite a bit of money on it but… Believe me, if I would’ve fucked up buying something expensive and it’s not any good I would tell you!
pictures still to come..
it’s been a good day 🙂
(everyone in the shop tried it and it did bring out the “Kramer face”)
  • IMG_1913
@panteradoug posted:
I don't see any negative issues with power steering in the Pantera. They are all just positives. If you can swing it, do it. It helps tame the beast.
I haven't driven my Pantera with the SACC power steering, but will be in a few days. One question that I have is how hard will it be to steer the car if the power assist unit loses power or fails? I am sure that it will be possible because a lot of new cars have electric power steering.
@jffr posted:
It will just feel like it did before you put the PS in.
I opted for Bruno's automatic "communications satellite" device. It adjusts the boost automatically determined by the vehicle speed. That's what the satellite is needed for. There is at least one in orbit for everyplace on the planet sans Antarctica. Works well.
The only criticism I hear is from those who didn't invent this first? Those guys can get really nasty at times.
I realize that sometimes my socks don't match but there is a logical reason for that. It apparently escapes them?  They don't need to point that out to me. I already knew that. I like to solve problems simply.
I advise putting in the 100amp alternator though. The PS motor takes a lot of power even though it is such a little motor.
@jffr posted:
you already have it installed?? If so - that’s how it feels - ignition off… wheels on the ground - not moving!
once you drive things are changing.. does your PS decrease assistance?
The drag of the EZ system is like what a well greased bearing feels like when you turn it.. I did try that when it was still out…
installed you can’t detect an increase in effort when not powered up!
I opted for Bruno's automatic "communications satellite" device. It adjusts the boost automatically determined by the vehicle speed. That's what the satellite is needed for. There is at least one in orbit for everyplace on the planet sans Antarctica. Works well.i advise putting in the 100amp alternator though. The PS motor takes a lot of power even though it is such a little motor.
I did do the alternator upgrade 👍
In some tunnels in Switzerland or Italy I do loose the satellite (GPS goes offline) but how often do you parallel park in a tunnel 🤪… - parking garages I don’t know..
my main reason for opting for this system was the small motor and the angle the motor sits in the system.. it points upwards maybe 11 o’clock.. you don’t even see it and it doesn’t interfere with the legroom on the left side!IMG_1915
the bottom of the “Brain-Box” I pretty much flush with the steering column cover..
  • IMG_1915
@jffr posted:
I just did my first test drive with the SACC electric power steering unit and I am impressed! It wasn't the easiest project that I have ever done on the Pantera, but it was well worth the expense and effort.
Congratulations !
That is great to hear!! Nothing to do with “wimpy” - it has to do with making something more enjoyable! And yes, it is quite some work and quite some expense but so worth it!IMG_1928
  • IMG_1928
@LeMans850i posted:
Congratulations !
Thanks, but due to a recent shoulder replacement, this power steering unit made driving the Pantera so much easier. What also helped me to go with power steering was a professional race car driver and driving instructor at the Inde Motorsport Ranch. He really liked driving the Pantera, but wasn't thrilled by how hard it was to steer at very low speeds. I plan on going back to that track before the September Pantera Prowl event there and doing some testing.
