Hi,
I know this have been up before but...
I swaped from IPSCO´s low profile ITB to my older TWM and they have
an extreme load to press with the accelerator. Now, is it a good idea to
release/remove the springs on the ITB´s ( two or all four) and use a return spring connected to the bell crank instead?
Thanks!
Anders
Hi Anders,
I am not sure I completely understand your setup but I will say that it is a very good idea to have return springs at the throttles to ensure positive throttle control. Most sanctioning bodies require them (for non drive-by-wire) and for good reason. The are your end of line safeguard. Many good quality throttle bodies have built in springs.
Have you checked your throttle cable? They can add resistance.
Most multi throttle body systems I can remember had some sort of spring for the throttle body(s) and a spring (or springs) at the bell crank or at the end of the cable. The intermediate linkage(s) have a little adjustment so throttles can be sync'd and to be able to adjust the idle.
There should be no difference in feel from one system to the other.
Since it is likely that you had much of the throttle disassembled, there might be an issue with the way you reassembled it.
I have a Moroso double return spring installed to the bellcrank arm which is mounted to the center tower of the Weber manifold.
I initially had issues with the weight of the tension on the accelerator. I am using the original Pantera throttle cable.
What I discovered was that in that cable assembly, on the carburetor end is a metal tube that is used for the internal spring to ride over.
If that tube gets bent or deformed in any way, it causes increased effort on the accelerator.
I removed the tube from the cable assembly and now have a very light feel to the pedal. I would and have recommended the tube removal to anyone who asks. It likely is the source of the issue in many cases and really is not a necessary or critical component to proper operation. It just causes trouble.
Also in reassembling the throttle arms to the TB's, the linkage must be at 180°, neutral and not over centered.
You do not want to add additional throttle springs if possible. Regardless of if you are using Weber 48 IDA's or EFI TB's, the throttle shafts will wear prematurely if significant spring tension is added to the throttle assembly.
A follow up...
I start all over from scratch. Panteradoug, thank you for your advice.
I made a new bracket, steady as... and bolted on a brand new bellcrank meassured to the center between the throttle bodies and a new wire. It's a Dream to drive now.
Do it right from the begining...
Happy driving to you all
Anders
@sf posted:
A follow up...
Anders
Yep. It isn't rocket science, it is just different from what you have seen before.
Once you understand this type of multiple carb/throttle body linkage you will be good forever.
On the Pantera, that center tower pivot is very important AND there is a degree of incompatibility to the original cable throttle that needs to be modified.
The "tower" makes it "easy" to run the left and right side throttles opposite to each other with little or no change to hot idle rpm because of heat expansion on the linkages with a light feel to the throttle pedal.
Considering that all was intended to maximize the potential of the intake as a race design, it is a very sophisticated idea most often overlooked as poppycock by  self proclaimed nouveau experts, which it definitely is not.
