OK - My Turn Signal Flashers and Hazard Blinkers don't work. I believe it is in the power to the Flasher Unit, but I can't figure it out.....
I am using this diagram.
I bypassed the Power and Ground and hooked the Flasher unit directly to the battery. I connected the flasher output into the Harness Pin 49a (Flash). Everything works fine (Therefore - I think the flasher unit is good).
When the Flasher unit is not connected, I get power to the flasher (Pin 49) from my harness at 11.7 V. This seems like it is only tied to Fuze 12 (and not Fuze 8, as the diagram shows).... This could be a clue...
Anyway - when I hook the flasher into the socket directly, I only get 1.5 V at both the Flasher Power (Pin 49) and Flash (Pin 49a). None of my lights will flash when either the Hazard Switch or the Turn signals are activated.
Fuze 12 supposedly goes to the following:
Rad Fans - Work (Hall Mariah Fans)
Stop Lights - Work
Instrumtents - Work
Back-Up Lights - DON'T Work
Turn Signals - DON'T Work
Any help would be appreciated. This is killing me.
Files (1)
