...You Melted the Control Module!
Points?? They're Burned Up Along with it's Condenser and the Coil. You can, in all likelihood...count the Voltage Regulator Out, also! And I would 'Lay Money' on the Alternator is also, Gone! When 'Things' Melt, Everything gets Shorted.
MJ
...you will not forget a second time, Only WHEN you install a 'Master Disconnect Switch', on the Battery Ground Cable...WITH a RED Idiot Light that is ON, when the System has been activated! They Don't call it a 'Idiot Light', for Noth'in.
...P.S. On the Distributor-less Ignition I run, if left on for 1 Minute, while the Engine is NOT Running, it Automatically Shuts Down. A Nice 'Double' Safety.
