Another update from Tod
I am being inundated with work requests right now. It is nice to be able to run regular production without stopping to machine a block or two. The second machine center was a good buy. There are currently 3 pallets and I am trying to buy more so I can run other stuff too, without set up time.
The real suprise is that my foundry is actually wanting to cast blocks now! They bought a second building and have more than tripled their space so they need the work. Good.
I just purchased a couple of additional boring tools to make boring the mains and cylinders easier. Can't wait to get to that point.
Tod
-G
Originally posted by 73 l:
are these dealers going to be the only way to buy the block?
Dealer/builders is my preference but if a guy has a good finish machine shop and wants to go his own route, I will probably end up selling some that way. The reason I need dealers is that I can't afford the time dealing with all the variables that accompany all the desired builds. I learned the lesson when Robert Pond and I were still in business together. We ended up machining a basic FE block that could be used for every build and sold those to dealers. I am not Burger King, and can't make every imaginable machining combination.
Hope that helps.
Tod
tod i agree with what your philosphy i know i can't build an engine just wanted ablock so my local machine shop guy can build it for me (the aluminum block to save weight)i'm good at what i do and appreciate that others are good at what they do (like building engines) what is the new price on a aluminum block? and aprox. availibilty?
February 1, 2013
I've had some good news reported back about one of the first aluminum block builds.
I was told:
The motor was built for drag racing and is installed in a 1970 Mustang Sportsroof weighing about 3,260 pounds with driver. The owner made a few quarter mile runs, and the best time was 10.93 seconds at 122 MPH (6.65 @102 in the 1/8 mile). That was slower than expected. The data log from the motor's EFI computer (which looks at AFR, injector duty cycle, MAF values and RPM) says at WOT the engine is consistently producing 650 HP at 7,000 RPM. The owner believes the car is losing a lot of horsepower in the auto tranny; he believes when he reduces the driveline losses the car should run in the low 10s in the quarter.
He also said the block has been totally defect and problem free!!
Meanwhile I've been making chips on some small parts on the new machine just to get used to it and so far the machine is performing fine.
Tod
-G
March 19, 2013
I've started test running the new machining setup in the new (second) cnc machine center. So far, so good!
I want to make sure the program runs smoothly and error free, because the new cnc machine is a completely different machine, utilizing a different controller, and requiring a different tooling setup than the first one. It's a tedious process, but I hope to avoid problems cropping up when its time for the new machine center to start turning out blocks.
Tod
-G
March 26, 2013
It looks good!
I've run the 1st OP program several times now to make sure all of my program runs without a hitch. I'm very pleased. Now it's time to make some chips.
I'm working on reducing builder machining as much as possible. From my discussions with a few builders I think we have hit upon a plan of action to make the blocks to suit most everyone.
Tod
-G
April 26, 2013
Well, I just finished gun drilling the first three oil galleys all the way through. Prior to this capacity I could only drill them most of the way and let the builders finish them out. Not any more.
I also adjusted my cam boring tool to take more stock out so there is less machine work to do there too. The crank will still match the diameter of the ProGram caps.
Tod
-G
Originally posted by tarik2cyprian:
Hello Tod
Glad to see that you are making progress since my last message since July of 2011.
Does the aluminum block come with hexagon brass threaded freeze plugs and with four bolt main bearing caps made of 416 stainless steel.
What is your estimated cost for the aluminum block?
Thanks Once Again
Tarik Richards
Tarik, the blocks come with hex steel freeze plugs and 4 bolt main caps out of whatever steel Pro-Gram uses. I'm aiming for a 3000.00 price range from me, ready to be finish machined by a builder. My cost for sleeves went up dramatically so I need to add that increase in. I am taking steps to reduce the amount of finish machining since I first began.
As this is progressing, it looks like I may end up selling only through dealer/machinists. I want to keep things as contained as possible, and quite frankly, there are some people I don't want anywhere near my blocks.
Tod
May 4, 2013
I am setting up the 2nd OP and needed to see if I could get a block to clean up for a taller deck. At 9.37 there is no problem at all. That allows it to easily be decked to 9.35. I already have one order for this kind of thing.
I'm also adding gun drilling of the galleys, which is better and faster. I'm adding a 3rd OP to bore the cam and crank as close as possible, being set up off of the decks after they are machined. That keeps the cam and crank aligned with the decks. It also allows me to bore the crank journals after bolting on the caps.
I've been having a discussion with Durabond about cam bearings.
So far my blocks have been built utilizing a #1 journal cam bearing from one set of bearings and #2-5 from another set. The machinists are using Durabond 351HP bearings which are 2.205 OD. They finish 2-5 to use these 4 bearings and finish #1 to FP-26-1 which is a stock size bearing. That way they go straight through and then enlarge #1. Problem with this is that you can't just finish the journals straight through and be done with it. You still have to cut the front one larger. That has GOT to be a pain in the keester.
For those unfamiliar with aftermarket blocks, you can't buy an aftermarket Windsor block that uses stock cam bearings. Using non-factory cam bearings is not unusual. On our 427 FE project, Pond and I changed to a straight through cam bore with bearings that stepped down in ID and there have been no complaints after all these years and hundreds of blocks. It makes finish machining MUCH easier. I'm in the process of determining the preference of builders and machinists in regards to the 351C block.
Durabond told me they could assemble a special package and number for me which is four of the 351HP bearings for journals 2-5 and one of the FP-26-1 bearings for journal #1. That just may be the best way to go, for now.
Durabond says they could make a set to my specs that are the same OD for all 5 journals, requiring only one straight through machining op, but the bearing sets will cost more. They told me they would need an order amount of 200-300 sets to make an "all 5 the same OD" package. In my opinion the extra cost of the bearings is a wash next to the extra cost (and pain) of cutting the #1 by itself. The block will use stock 351C cam cores either way, the IDs of the cam bearings would be the same as the stock bearings. Its the OD of the cam bearings that is juggled to make the block easier to machine for the engine builder.
I am just trying to cut a wide path as the 351C block project ramps into production.
Barry R of Survival Motorsports is getting ready to dyno an engine he assembled using one of my alloy blocks and a pair of Scott Cook heads. The results should be available soon. Anything I learn from Barry will be incorporated into current production.
-G
Here's a link to a YouTube video of the engine mentioned by Tod on the dyno at Survival Motorsports. The engine was assembled utilizing an aluminum version of Tod Buttermore's 351C block, and Scott Cook's aluminum 351C 4V heads. The engine was built by Barry Rabotnick of Survival Motorsports. The customer is a Pantera owner.
412 cubic inch all aluminum Cleveland built by Barry Rabotnick
  • 412 cubic inches - 4.125" bore x 3.850" stroke
  • Runs on pump gas
  • Hydraulic roller cam (236° @.050", 0.600" lift)
  • Independent runner EFI with an EZ-EFI controller
  • 570 BHP at 5800 RPM
  • 534 foot pounds torque at 5100 RPM
  • Torque was over 500 foot pounds at 4500 RPM and stayed there until 5900 RPM
-G
July 29, 2013
I just finished the first block to come out of the new machine and new programming. It is the block machined for a 9.35 deck height I mentioned in May. I still need to make a few adjustments due to new programming, tooling, and all sorts of other variables, but I think it came out alright. Tim Meyer will be building it for a customer in Australia.
Tod
Pictures are below.
-G
Yes actually.
Tod is slowly producing blocks and getting them into the hands of machinists (engine builders) who have customers desiring to build an engine using Tod's block as a foundation. Tod is waiting to see if any problems crop up, listening to comments from the machinists, waiting to see the finished results of the engine projects. In other words he's being very cautious, making sure the block molds (aluminum & iron) and his machining programs are as perfected as he can make them. He's trying to avoid having problems crop-up after the blocks get into the hands of a large number of customers. I'm sure he wants to get several builds under his belt before he announces he's ready to begin casting blocks in greater numbers.
I also know his desire is to establish a small network of engine shops that will handle sales & final machining of his blocks; I don't know what progress he's made along those lines.
Here's a link to a You Tube video of an all aluminum 412 cubic inch Cleveland using an aluminum version of Tod's block, Scott Cook heads and IR fuel injection. The build was performed earlier this year by Barry Robotnick of Survival Motorsports. Judging from the pulleys on the front of the motor this engine went into a Pantera.
July 8, 2014
Another update from Tod ... GOOD NEWS! ... its been over 7 years since we started down this path, but the wait appears to be over.
Block production is back under way. The machine is running after tracking down electrical problems. It took 3 attempts to finally get my spindle drive right (plus pulling the motor and having it all gone over to ensure it was not an issue). Then I ended up having to totally rewire the motor harness. Locating that wire was a week-long chore.
I have all casting problems resolved and can cast blocks without reservation now. And now that the block machine is running again I will not be stopping production unless there are no customers or there is another machine issue.
I just finished machining a block this morning and another one is cutting right now. After 6 more aluminum blocks are cast and machined all first depositors will be taken care of. Two of those 6 blocks are already cast and ready to machine.
I plan to revisit all my emails regarding iron blocks and see who all wanted one and let them know iron blocks are available. There were a lot of people wanting one but I was forced to tell them I would not take their deposits until I was sure (1) the castings were repeatable, and (2) the machine was ready. THAT TIME IS NOW!
I can start making castings when I get orders now. I should be able to make at least one block a week. I can probably cast 2 a week.
Please contact Tim Meyer for purchases that need finish machined to your specs. I am trying to push all finish machining his way and he is working on being the public liaison for selling these. There will probably end up being some exceptions but the norm shall be for people to deal with Tim.
Tim's info:
TMeyer
1121 Marcus Street
Fairmont, MN 56031
507-238-4141
fordmachinist@gmail.com
Thanks and appreciation to everyone who has been patient and supportive.
-Tod
-G
Well, what do you know, I was able to figure out what password I used, after my computer crashed.
I did indeed just cast 4 more aluminum blocks, and plan to cast 4 more soon. I have a couple of iron to replace due to bad castings but I think i just figured out what went wrong and was able to test the fix on the last 4 aluminum blocks, which usually were good. The iron, being heavier, seemed to move one of the water jackets where the aluminum did not. I tried a solution and it did as I hoped in aluminum, so I will be doing it with some iron next. I have iron molds ready to go, so I am anxious to get that going again.
Tod
Well I have seen this on facebook and Tim has sent emails to folks on this topic but the message is Tim Myers is buying Tod Buttermore's aluminum and cast iron blocks.
Well here is the email.
I am very happy to inform everybody that as of Wednesday the 12th, we have agreed to terms with Tod Buttermore
and the purchase of the Cleveland block project.
Our goal is to pick up the tooling on the next 2-3 weeks and then deliver it to the foundry.
There are upgrades we are planning on, so they estimate about 6 weeks from the time we drop off the tooling
until they can supply us with a sample block.
We hope to be producing blocks before the end of the year.
You are receiving this email because we have your name on a waiting list.
We currently have about 30 some names on a waiting list.
Many have asked about putting down a deposit, and at this point we will
not want a deposit until we are at the point where we have block casting ready to machine.
With the purchase of the Cleveland block, we are also purchasing a local machine shop that has the CNC equipment needed
to do all our machine shop in house. We will have an employee full time dedicated to the products we are manufacturing.
We are dedicated to “%100 American made” products!!
I will continue to keep you up to date on the blocks.
If you are no longer wanting a block, please let me know, I will take your name off the list.
ALSO…This is not %100 public yet.
We will be announcing this as soon as the tooling is in my hands!!
FYI…We are still excepting investors for a short time. If you are interested in a short term investment
that can yield %20-%30, let me know and I will forward you the information we have.
email sig
Here you go guys, this is the statement we released on Tuesday 25th
“Due to an unexpected increase of workload and an exciting new antique-engine project, I have closed a deal that has been in the works over the past couple of years with TMeyer, Inc. This arrangement will allow me to fulfill the last of my existing Cleveland obligations and then turn the project over to them for further advancement and needed focus that I can no longer provide to the project. I am fully confident in TMeyer’s abilities to continue this project, and I plan to be available as needed to assist through this transition. The Cleveland family of guys have been a pleasure to work with, and I will always view them favorably.” - Tod Buttermore
“TMeyer, Inc. is very excited about the acquisition of the Tod Buttermore, Cleveland-block project. Tod has gone to great lengths to provide a quality designed product that looks almost identical to an OE block on the outside. What Tod has done can only be described as “history-making.”
TMeyer, Inc. will continue to offer a premium product and a full-line of services needed to build a quality performance engine and is dedicated to producing a “100% American-made” product. The castings will be made in Manitowoc, Wisconsin, and with the purchase of a local CNC machine shop, TMeyer will have the ability to provide all of the machining required.
We at TMeyer, Inc. believe that with the current line of products TMeyer has to offer, the addition of the Buttermore Cleveland-block will set us apart as a one-stop-shop for all your Cleveland product needs.” - Tim Meyer (TMeyer, Inc.)
