Yuu can also get the identical pan from Armondo's Oil Pans. He's a little cheaper, but you don't get the Aviaid decal on the side.
My last engine had a Kevko pan and it fit great. I believe it was about the least expensive pan that I had found. It was a ten quart baffled road racing pan.
Trying to save a few dollars on a pan may risk a lot of dollars on a blown engine.
It is best to stay with a design that has been proven in competition to work.
I have noticed that other manufacturers have copied what Aviaid has done as far as the trap doors, the oil scraper and the windage tray.
Just having more oil in the pan doesn't necessarily solve the problem.
It has to stay in the right place to be picked up by the pump.
Life expectancy of an engine at 7000 rpm without oil pressure is in micro seconds.
You simply cannot criticize the Aviaid design. It works. Proceed at your own risk.
I have the Aviaid on my Pantera but went with a Canton road race pan on my 68 GT350 simply because it is identical to the Aviaid "Trans-Am" pan, and it was 1/2 the price.
Canton was smart enough to copy the Aviaid, and their workmanship is impeccable.
It is a proven design also, just not theirs. Wink
When it comes down to it there's not too much science in an oil pan, the main aspect being holding back oil within the baffled trap door section. Functionally the Kevko design acheives the same as the Aviaid/Armando design at a reduced price.
Its pretty interesting to look at the different pan designs. Just my observation on the design of the Kevco pans (some of the pictures are not the Pantera specific pan?)....some pan reservoirs sit out to the side of the pan which would seem to be better for a true road racing pan because it stores oil in a better location for lateral G's, and the flooding of the pickup area during side to side cornering motion. But with the chassis rails going fore and aft on a Pantera dictates design to fit in between the rails?
The Armando pan that I have has a very large reservoir fore and aft that stores the oil directly under the engine, but not out to the sides, probably to fit within the rails. The interesting part of cornering forces is, under acceleration/deceleration in a corner there isn't a 100% lateral force but a combination fore and aft (acceleration and deceleration) and lateral (side to side) effects on the oil and the baffles. On the Armando pan he's places a baffle box around the pickup that gives a 45 degree angle to the baffles and separate reservoirs for each baffle door which takes into account the lateral cornering/decel/accel motions. The pickup that comes with the Armando pan is also much smaller than a stock pickup. Also the largest part of the reservoir is placed at the front which would flood the pickup under acceleration.
When I bought my pan from Armando I recall the price was $350 but we did a group buy.
  • Armando_Pan_baffles
I may be mistaken but I believe the Armondo pan is identical to the Aviaid.
There is no room to go on the sides with additional tanks on the Pantera because of the rails.
The Mustangs have them and the Cobras also.
Initially the R model GT350's used the Aviaid Cobra 289 race pan. The 289 Cobra does not have a cross brace behind the sump like the Mustang does so the pan is long like the Panteras is.
The pan that became called the R model pan is essentially a 289 Cobra race pan with the shortening of the sump to accommodate the Mustangs rear cross brace.
If you look at the "Trans-am" Mustang pans you will see two that I know of.
One is by Aviaid and ends or starts under the balancer like a stock pan. The Bud Moore version extends forward under the front anti-sway bar at a 45 degree angle AND has a skid pad added.
The skid pad was necessary because chassis travel but the forward extension dangerously low.
All of these pans are chassis specific in order to fit the chassis of the intended vehicle.
SOME of the vintage Mustang racers will ONLY use the AVIAID stating that they blew engines with other manufactures pans.
I can tell you that my Canton Mustang pan is IDENTICAL TO THE AVIAID but there are at least two racers that I know of that blew engines with it and blamed the pan. They went back to Aviaid.
Yes the oil pans are interesting.
The Pantera doesn't have the reputation for blowing up race engines due to inadequate oiling.
The problem they had when they were factory raced was that Bud Moore, who supplied the engines to Detomaso used Hank the Crank crankshafts which were internally balanced.
For some inexplicable reason the Mallory metal wouldn't stay in the crankshaft in the Pantera, and yet that engine was being raced in NASCAR at the time as delivered to Detomaso.
Very strange. Maybe just those Italian saints needed homage that they didn't get.
When the cars were running they were as fast as anything on the track. The engines just wouldn't stay together.
Detomaso asked Ford for help on engine development but this was at a time when Ford was bailing out of the Pantera program.
Bad timing for sure.
Detomaso blamed Ford, and Shelby too. Fact is he needed to step up and take his own destiny in his own hands and was not capable of organizing a team himself.
Anyway, the Aviaid is the original race design pan and it works. If it isn't broken...don't fix it.
Doug you're right on the chassis specific issues. I remember the Boss 302 cars getting these crazy looking wide pans with reservoirs sticking out the side but they had plenty of room.
Interesting to then look at dry sump systems that needed to be developed around the late 60's early 70's because the lateral G's were getting so high due to better tire compounds that a wet sump just couldn't keep the pickups covered (CanAm cars that could generate 1 to 1.5 G's in a corner).
The Mustangs really don't have plenty of room at all.
The lower control arm pivot point is close in there, and that's the same volume of space that
the headers want to occupy.
the Pantera actually has less obstructions and the "boat" pan design fits in very well.
There were more then a few dry sump cars built but space becomes and issue with some of them. You need a place to put the oil tank and the size of the oil lines are at least -12. Then you need to work the pumps in. Forget about it in a Pantera.
This is one of the reasons that Carrol Smith deemed the Pantera unraceable for Ford. Ford basically abandoning the car after that report. The GT40 having been conceived of as a race car from the beginning was more adaptable to necessary accessories like a dry sump, and access to it because of the flip tops. The Pantera being a GT doesn't adapt well to all out racing requirements as it is built new.
The GT40's were the first I remember seeing with dry sumps and I think those were the Mk II's (the 427 cars). Certainly the Mk IV is dry sump.
I don't remember if the Mark I Shelby Team cars are wet or dry sump.
The only major differences I have seen that are available in a wet sump are the SB Chevys. They have an optional "swing" pick-up.
You'd have to ask Randy Gillis but I think most of the Trans-Am Boss 302 cars got the Bud Moore stile pans.
This is the SB Ford Trans-Am pan for the Mustangs. The Bud Moore is a little different in the front and projects further making it necessary to use a skid plate on it.
  • Canton_SB_RR_oil_pan
I have one of these on my engine. Its an old Moroso oil pan, My car was freshened up by Hall, this was one of what he did. The others were not around at the time so it was limited. Its probably a high capacity for the time but, I can tell you it is not baffled well if at all, I know this because I have lost oil pressure in hard cornering. I will probably go with an Armando pan on my new/refreshed 351C when the time comes unless I am convinced otherwise, second is the Kevco.
From what I heard or read Armando use to work for Avaid or Canton and stated doing his own thing here in calif, but is know in Texas, Kevco is another guy who started up and is making pans, all good but who's the best?????
Mark
You need a full road race oil pan. Canton and Moroso do not list one for the Pantera.
Aviaid, Armondo, and Kevko do.
A Mustang pan with side tanks might fit, but I doubt it. That's why there is a Pantera specific pan.
Kevko isn't even showing accurate photos of it, so to me it is a bit of a mystery.
I personally went with the Aviaid. Armondo used to be a lot less...but times have changed? It is identical to the Aviaid...except for the decal.
The Kevko is over $100 less.
The only thing I'm disappointed in with any of them is I would prefer the pan to have bungs fore and aft for oil drain back tubes as shown on the recommended oil pan in the Ford Boss 302 Engine Modification for racing.
A lot of people say they aren't needed but I like the option of having them available.
How much is a new engine? Is it more than $100?
Bud Moore Trans Am MUSTANG pan with skidplate.
The side tanks won't fit in a Pantera.
  • Bud_Moore_pan_with_skid_plate
I say give the Kevko pan a shot. Take a look at this photo of the Kevko pan, it looks almost identical to the Armando pan. The windage tray, scraper, side construction and bolt holes to hold the windage tray look identical, if you look down inside the sump area it looks the the baffling is at an angle just like the internals on my Armando pan (see earlier pic in this thread). I'm betting that Aviad did the R&D, and Armando and Kevko copied the pan. I'll post a picture of my Armando pan with the windage tray installed.
  • Kevco_Pan
I personally went with the Aviaid. Armondo is $25 less. It is identical to the Aviaid...except for the decal.
Doug,
I think you're right, let's go for a proven solution ... Aviaid or Armando
FWIW:
Kevco: Last summer, I purchased a Kevco Pantera 351C oil pan for a friend. He had his mechanic install the pan, so I didn't actually see the problem. All of the bolt holes (except for the front and rear 5/16" bolt holes) on one of the pan's rails were waaay off. The mechanic called Kevco. The person that he spoke with at Kevco was not very friendly upon hearing the problem, and insisted that their products always fit, yada yada. They finally agreed to send another pan, but only if the customer paid (again) for it. Since the engine was out of the car and waiting for the oil pan, this was the most expeditious way to finish the project.
The new oil pan fit better, but the mechanic still had to slightly elongate the same problem holes. Kevco sent a call tag (with the replacement pan) for returning the first pan. It took over a month (with phone calls almost every day) to receive a refund.
This may have just been a one-off problem, but I don't know.
Aviaid: Last month, I installed an Aviaid pan on a friend's Pantera. I placed the pan upside down on a flat surface. The pan's rails did not sit flat on the "test" surface. The pan had a slight twist. It would "rock" slightly, pivoting on diagonally opposite corners. A slight downward pressure on the pan caused the rails to sit flat against the test surface, but releasing the pressure caused the pan to return back to its previous state. I determined that the pan bolts would take care of the pan's slight twist.
Upon installing the pan on the engine, I discovered that the bolt holes on the pan's right side rail were slightly off, but that the bolts could be started by hand. The install was successful.
Armondo: No experience.
Recent prices:
Kevco $330.00
Aviaid $437.95
Armondo $439.00
John
John, the problem is that the cores are no longer Ford. They are aftermarket.
At one time you had to send Aviaid your original pan in exchange.
I have only installed two of these pans. Aviaid on the Pantera, and Canton on my 68 Shelby.
I used ARP pan studs on both and used flanged hex nuts on both.
Both pans needed to be jacked up into place on a floor jack and then tapped down into place.
I may have enlarged the holes in the pan slightly as well.
Considering that they are gas welded on relatively thin gauge sheet steel, I'm not shocked that either need to be fit.
I would expect that from any of them.
As the expression goes, "there is no such thing as a true bolt on!" Big Grin
I've seen worse. I had a set of JBA headers for the 68 Shelby that I paid $995 for. They were absolutely beautiful out of the box and fit perfectly, sort of... except for one little thing...the pitman arm hit the #5 tube and as a result the car couldn't turn left. OOOPS!
Oh, and the special z-bar they made for this setup, it didn't fit either. Roll Eyes
Don't buy JBA.
Well they refunded my money, but I had to pay to ship them back AND they blamed the RETAILER and took the refund out of his account.
I have a ball peen hammer here just for explaining things to them. I just love to meet with factory Reps. Big Grin I guaranty they won't pull attitude on me EVER AGAIN AND SURVIVE...PROMISE! Don't worry, even if they do survive...they don't remember a thing...especially their own names. Something to do with experiencing sudden impact?
Wink
The retailer used different tactics. He dropped the entire JBA line. Smiler
I would recommend the Aviaid pan for the Pantera or the Canton for a Mustang for that matter. Issues for either are relatively minor. Both are excellent quality.
The Pantera pan hasn't come off since original install but the Canton has. On re install the Canton went right back on. None of this twisted/misalignment of the original install.
It took the proper set after running the car.
An aluminum pan sounds nice, but around here pits even just sitting in the garage. Sounds nice though. These steel pans aren't particularly light.
Originally posted by Chris Wilson:
Installed an Aviad pan a month or so ago, purchased from Bob Byers, bolted straight on no problems,
to be picky the construction workmanship is a little to be desired all the welds are laped not butt welded, and the plating was only so so. polished up well with some 000 steel wool though.
The welding is similar on all of them but the
Canton workmanship presentation is better but remember these are made as race pans, not for cosmetics.
Plating is just gold cad. I'll probably send it for power coating next time it comes out?
Here's the deep sump Moroso pan that fits on a Pantera. All it is, is a deeper sump with no baffles. The stock pan is better with it's minimal baffling I think.
  • Moroso_9qt_351c__pan
Guys,
after all discussions about WHICH alternative pan to take:
Do i really need a special pan?
Engine is a 408 with road tires an big external oil cooler.
I am just assembling my car, unfortunately the guy who built the engine used a oil pan for the Mustang, it simply doesn't fit into the pantera. I am located in Europe, so ordering a special one takes long and is VERY expensive.
So, do i really need a special one or can i use the original pan?
Thanks
Andy
It depends on your usage. If you never intend to use the car driven hard and just are going to drive it around like you would your 72 Country Squire station wagon then the answer is probably no you don't, but I would at least use the Boss 351 pan with the internal baffling.
But then again I'd question why you need 408 cubes, an oil cooler and a Pantera. But that's just me. I'm just the burr under the horses saddle, but then again, everyone here already knew that. Smiler
The 351 Cobra Jet motor had the same pan as the 351 HO (Boss) motor. See the picture below. No baffles, just a minimalist windage tray & mid-section scraper. Don't forget the high volume oil pick-up (also in the picture), another integral part of the factory performance oil pan.
As an alternative the standard pan can be used with an aftermarket windage tray available from Milodon & Moroso, plus the high volume pick-up.
... I'm just the burr under the horses saddle ...
Smiler
  • cobra_jet_oil_pan
Originally posted by "72 GTS:
Well
I've heard about front or rear oil pickup ?
Does this engine works two ways ?
I'll soon make my decision since Kevco has not replied my mail (rather uncomon for american guys !)
Not that I know of. There is only front pick up for a Pantera and I've not seen an application where the Cleveland oil pan needed to be modified into a rear pick-up.
What you may be thinking about is that in the 70's the 302 was being installed into the Mustang II, and in order to do that Ford had to make a duel sump pan, small one in front, bigger one in rear, in order to fit the 302 into that chassis.
There are some dual sump pans made for racing but it is the chassis configuration that determines which pan configuration to use.
Even though they are duel sump, they are still just single pick-up. The oil pump would be in the front just above the small sump and thr pickup would be in the rear sump on an extended tube to reach it.
I would call Kevko and not wait for them to email me back. For the difference in the price I'd go with the Aviaid, and did. You can't go wrong with it.
I did notice one thing with the Kevko though. The oil scraper is not the full length of the pan. On the Aviaid, it is.
Ford trucks with the Windsor used a rear sump oil pan.
I noticed that too.
John
@ PanteraDoug: The car is not for racing purpose, but also not for cruising only, so 1G cornering forces should be possible.
The question is which benefits a big sump has. For cornering only a deeper pan or some baffles make sense, a wider one does not garantee a better oil supply when cornering from my point of view. On the other hand more oil is good to equalize temperature peaks, but for this i have the oil cooler. So any ideas what the difference really makes?
Thanks
Andy
John
Same issue. Front suspension is in the way. Ford cross beams and all. But it all works out. The Pantera has none of that in the way for a front sump.
The question is which benefits a big sump has. For cornering only a deeper pan or some baffles make sense, a wider one does not guarantee a better oil supply when cornering from my point of view. On the other hand more oil is good to equalize temperature peaks, but for this i have the oil cooler. So any ideas what the difference really makes?
Thanks
Andy
I think it more then coinsidence that 10 quarts seems to be the norm with a high performance oil pan.
With 5 quarts the engine is capable of pumping the pan dry at upper rpms. There is a reason most Fords, even high performance ones are restricted to 6000 rpm.
Just drag racing a Boss 351 with a 7000rpm limit, the car needs 8 quarts. Been there done that.
There are no side tanks for these pans on the Pantera. The extra capacity is added to the rear of the sump.
It all depends on the intended use? I had my car on Ford's Utica, MI test track. It has banked turns. 100mph is nothing on that track. Old ladys in shopping carts were going 125 through the turns. Where so you think the oil goes at 125 mph on a banked turn without internal baffling in the pan?
To me the Aviad pan is cheap insurance compared to what I have invested in the engine.
Did I even tell you that I spun in my own oil when I blew up the oil cooler hose? That could have cost a lot more then just an engine. Now all the hoses are braided metallic.
All personal choice. Personal perspective.
Everything I have done is for a reason.
There is a similarity here with being a fighter pilot. 99% of the time is sheer boredom, but the other 1% is pure terror. You don't have even time to think if all your equipment is ready to run. You just do it, but under those stresses a mechanical failure is sure death.
99% of the time in a car you need nothing of things like this. It's the 1% you need to provide for.
Best to be prepared without hesitation to my way of thinking.
I've done what I can to show anyone who is interested alternatives. Gentlemen, the choices are yours. Wink
Thanks Doug
Here's a picture of the engine at this time.
Needs a nice pretty gold oil pan! Wink
Those remote filter hoses are huge. They look to be at least -12. Big Mommas! Big Grin
I'm running -10 lines to the right side of the car where I have a dual remote filter mounted to the chassis and the hoses continue through to an oil cooler (like in the picture I posted) to the right side splash shield.
I have room in that spot because I'm running 180 degree headers which go up rather then down and under the chassis. This opens that area up to the oil filter and cooler use. Also have a Mocal oil cooler thermostat on the set up along with an auxiliary electric fan that turns on at 210 F automatically to blow through the cooler.
Those look to me like -12 hoses. The AN system means that a -12 hose is 12/16", or 3/4"id.
The metric equivelent is 19.06mm. That's huge.
Usually -8 or 1/2" (and these are ID or inside diameter hoses) are recommended for an oiling system,
On my car I used -10, or 5/8" or 15.875mm id hoses. Those are plenty big enough.
USUALLY on dry sump systems you would use -12 hoses. Sometimes -16 or 1" or 25.4mm.
I definitely would eliminate as much of the unnecessary hose as possible. All that additional hose is an additional strain on the oil pump for no reason.
I understand the thought of using a remote oil filter and I suppose it is your choice of where to put it but I picked a different location then that.
When I did mine, it was before digital cameras and certainly before the days of my Sony digital, so I didn't take pictures.
As I said, I mounted my remote filter on the chassis near the right engine mount. I snaked the hoses under the oil pan over the chassis cross brace.
The Aviaid pan is notched there to clear the stock cross brace and makes a good protected spot to bring the hoses around under the pan but over the brace.
You guys are going to make me go crawling around under the car taking pictures and revealing all of my secrets.
I wonder if I will find any women s underwear and hotel room keys that they threw at me in there? Huh?
Probably just from the fat ones that you could make a tent out of? Roll Eyes
