YEAH! Small hands. Reminds me of the time I convinced the wife to reach through the quarter window space and put her thumb over #1 cylinder while I was preparing to turn the engine with the ratchet and explaining to her to let me know "when the air blows your thumb off". The last I saw her she was slamming the door from the garage to the utility room. Guess I should have been more (or less) descriptive. First and last time assist!
Originally posted by Rocky:
...Hot water (to help stretch hose over the water pump inlet - it's bigger than the stainless tube)
...Manual Heater Cutoff for Track Events
Is there any reason the stainless tube could not be made the same size as the pump inlet and a larger diamater hose used?
are you still using the remote heater control valve? if so, is it before the new shutoffs so that it recircs when "off" even when shutoffs are closed?
That's how my valves and shut-offs are configured.
I was told that the recirc system wouldn't pass muster at a track event even though it would keep 90% + of the hot coolant out of the cockpit (my estimate).
On hose sizing - a person could do that, but I never even considered changing the stainless tube.... That looks like it would be a lot of (relatively precise, skilled) work. I never thought the hose install would be as hard as it was.
I knew the hose would go on..... But it was tough to do.
Making Progress.....
Bay Wiring Complete:
Flaming River Shifter U-Joints
My Dual Stock Rear Calipers (Old School)
OK, Haters can hate, but I can lock up my rears if I want - I prevent this with proper settings on my proportioning valve.
I know I can get a lighter weight rear brakes setup, but I've got bigger fish to fry in the near term, plus this gives me an E-brake without a lot of screwing around.
Note the Remote Heater Valve (See POCA Jan 2016 Newsletter for fabrication instructions)
Carb, Oil& Dizzy...
Almost ready to start!
Now exactly where am I going to get another rear set of calipers?
I'll bet all the vendors selling brake kits have a big pile of stock rear caliper sets. Guys that do them in the shop (Quella, Wilkensen, Byers) probably would love to get rid of them.
What struts are those, Aldens?
Those are the Koni K30s and Hyperco springs. I got the set from Pantera Performance Center (Quella). It was completely set up - bolted right in.
All you are going to do is start a run on Pantera rear calipers with this one.
What's old is new again. I believe this may have been one of the early brake upgrade mods popularized in the day. The availability of lightweight calipers made this trick go the way of the dinosaur.
JagCat -
So initially, when my ignition was set up, I reviewed George's Duraspark schematic, and saw that he uses the "official" Duraspark Coil (an oil-filled type), and an associated ballast resistor.
I set up my system initially with the ballast resistor but I decided to use the TFI (solid state) coil.
What I found was that at high RPMs, with the TFI coil, and ballast resistor, I would get an unexpected miss. It really disconcerting. I thought it was bad "lots of things" (wires, dist. cap, Duraspark module). What was funny was it would occur starting at high RPM, last for a while (until I stopped the car) and then start up and run fine, until the next time I got to high RPM.
I finally figured out that by removing the ballast resistor from of the circuit with the TFI coil, I solved the high RPM misfire problem. It seems to me it affects the charging current needed on the e-coils.
I just left the resistor in there, because I mounted it so nicely on that panel. The coil is bypassed by just shorting the two leads together, and tucking it into one of those harness sleeves.
As it turns out, a couple of vendors REBUILD stock calipers for people that want their Pantera stock-looking (none are actually stock. of course). I know of one vendor that cannot keep stock rebuilt calipers on the shelf. So as you say Rocky- quadruple stock rear calipers are heavy but simple and it works. You can mod the design later.
I had no problems just motoring around town with the TFI coil and ballast resistor. I Think the solid-state coil has numerous advantages, that's why I went with it.
George and I had a (respectful) discussion about the Duraspark II wiring diagram and my associated modifications. George, rightly so, stated that if you monkey around with the proven design then "you pays your money and you takes your chances". I have to agree with him there.
regards
Just a standard Duraspark (Ford Motorcraft) with the electronic pickup.
It's the same one that interfaces with the electronics box.
It was used on later model Ford cars and trucks (1975-1982 equipped with 351M, 400 or 460 V8).
Check this thread, and search for Duraspark II
That is a small cap with what kind of spark plug terminals male or female?? Grey? That is Motorcraft brand?
It's Alive, Take II!
We fired it up tonight, it ran for a short while, but (like a moron), I had neglected to charge the battery!
Anyway - fired right up, and idled smoothly. An excellent sign.
More work tomorrow, I'll probably drive it!
WHOO HOO!
PS> Look at this cool accoutrement - a 351C "Pre-Oiler"... Just plug it into the distributor cavity, and twist it with your drill motor... VIOLA! Oil Pressure prior to start-up!
  • Start-Up_02-19-2016_(5)_(Medium)
Mission Accomplished!
Still work to do, but..........
New engine installed, runs and drives!
ZF Rebuild Completed, no issues with:
  • 2nd Gear Syncro Cone Replacement
  • Taller 5th Gear
    Taurus Window Motor Conversion
    Remote Heater Valve Mods and Manual Heater Shutoff
    Reduced Bulkhead Cover
    ATO Fuse Box Install
    Battery Cut-Off Switch / New Battery
    Inset rear bumper
    Powder coated rear bumper and engine screens
    It's great to have a Pantera again!
  • Last edited by rocky
    Oh come on David - from what I read, you had two Panteras, and the second only took you 14 years to get it right (and IMHO - your white car was SUPER!)
    A little more progress...
    I completed the reduced bulkhead recover work!
    Results:
  • "New" Bulkhead Upholstery
  • "Quick Access" to Engine Cover
  • Mrs. Rocky gets three extra inches (legroom!)
    I'm thrilled with the results. Very nice fit.
    I updated the slideshow a couple posts up with pictures of Jim Click's Vintage Racers from "Fords on 4th" - a Tucson area car show held 03-13-2016.
    JT - The girl who is selling the Superformance GT-40 is looking for ~130K
    I've got the spec sheets - if you are interested - I can scan them and get them to you.
