A few of my personal thoughts on tire and wheel sizes FOR THE STREET; all have been tested by myself and my wife over 39 yrs of ownership with no crashes.
If you're attempting to maximize tread width and cornering, 225-50 x 15" fronts on 8" wide Campys seem a bit stretched. I don't use the 7" Campy version, I use 245-50x 15"s- about the widest front tread size one can run on an unflared Pantera body regardless of wheel diameter. Even then, some minor hammer-contouring must be done on the inner fender panels and fender lips rolled, for clearance in tight turns. More so if the U.S DOT bumper-height/headlight height spring spacers are removed and extra caster added. 8" Campy front wheels also correct the poor scrub-radius produced by 7" Campys. I suspect Dallara's first recommendation for the Pantera was for 8" fronts.... or else the excellent fit is pleasantly coincidental.
The first instance of 10" x 15" 'DeTomaso' Campy 5-window wheels were on the Euro Pantera GTS/Gr-3, noted in the 1972 GTS/Gr-3 Supplemental Pantera Parts Catalogue. Along with those wheels were listed 225-50 x15" P-7 front tires and 285-50x 15" P-7 rear tires. The rears were about the widest street tires available at the time and were used in club-racing & hill-climbs. 295-50 street sizes were not yet available or go-fasters would have snapped them up! GR-4 and GT-4 racers, of course used even wider slick 'gumball' racing tires with relocated a-arm points and flares.
 The 245-50 front/295-50 rear tire combination works well on the street on our '72, but to maximize big tire benefits, I use stock OD HOLLOW front antisway bars and HOLLOW 1" OD rear antisway bars. Hollow bars cold-bent of thickwall 4130 tubing are slightly less stiff than replacement solid bars of the same OD. The softer hollow-bar action works well with an otherwise stock Pantera chassis and drops about 50% of the unsprung weight of the bars. I also found it necessary to add Koni adjustable shocks front & rear with different springs (available in the '72 Gr-3 catalogue).
All this, along with all-custom alignment specs, a 2 degree nose-down attitude and a minimal Peter Revson front spoiler (the Gr-3 catalogue lists an equivalent front blade spoiler but I like Revson's curvy design), allows us to take full advantage of the remarkable handling and high speed stability Dallara gave the Pantera. Above 170 mph, a blade rear spoiler (or wing) might be needed for added anti-lift, according to regular SS runners. And if you're running way up there on the speedo on the street, you don't need MY suggestions! You may need a Viet Nam era 'get-out-of-jail-free' card, though...YMMV.
J DeRyke
Jack, good historical info.
There is also a benefit to going smaller on a given wheel width, stretching the tire a small amount. This promotes better sidewall action especially with modern performance tires using stiff sidewall construction.
My experiment with a 235/50-15 Toyo R888R on a 15”x10” wheel yielded some good benefits in transition speed due to the stiff sidewalls being at a more desirable angle in relation to the wheel bead.
Is ultimate overall lateral grip lower? Possibly. Is the reduced overall grip offset by more transition speed in mid corner performance? Possibly.
I have yet to perform instrumented testing back to back with a wider tire. That would prove challenging since same model tires in different, but appropriate tires sizes aren’t easy to come by in the 15” diameter.
I can only comment on track testing which proved to be excellent. The 235 R888R performed superbly on the 10” wheel. Ultimate lateral grip was stupendous and transitioning was much better than a “too wide” tire would have provided.
Another thing to consider is that published tire sizes are often guides rather than actual measurements. Case in point, the 235 R888R is actually 9.7” in width, which predicted its favourable performance and fit on an otherwise unadvisable 10” wide wheel.
Other 225 or 245 mm tires are often much narrower than their published widths may suggest.
However, for looks on the street, it may not be an aesthetic choice for most.
I was hoping to hear from someone who is running these new P7s at higher speed (over 100mph) extended to get their impressions versus the existing TB5/15, P7 Corsa Classic, P Zero, Avon and Yokohama AVS options that have been available.
The Get Out Of Jail Free card sure sounds good!
LS
GO TO JAIL
Lash apparently Dougal isn't following this topic. To get an answer to your question it may be more expedient to contact him via the Longstone Tyre website.
Jack, it is true the 15x10 Campy wheels came on the scene in late 1972 or 1973, but the 225mm & 285mm Pirelli P7s came on the scene in late 1977 or 1978. The 15x10 Campys where manufactured for a different tire which came on the scene in the summer of 1972 … the H60V15 Goodyear Arriva. It followed De Tomaso's convention of fitting tires on the widest wheel possible. The 15x10 wheel offset makes much better sense with a 255mm wide tire, which is set about 15mm inside the fender edge.
  • GO TO JAIL
lashss posted:
Dougal, I assume these “new” 285 and 345 P7s are fully endorsed (as noted by their official speed rating) for extended, high speed use?
Anyone with first hand experience on these “new” P7s at extended high speed?
Thank you,
LS
these tyres are Y rated
https://www.longstonetyres.co....li-cinturato-p7.html
so that is 300kmh (thats about 200mph). the load and speed ratings are listed on these pages
Rene, running slightly larger OD  but narrower rear tires causes no particular problem on a Pantera. All they do is slightly re-gear the final drive to the pavement and, if you have the torque available, maybe a bit more speed in all gears. I ran 275-55x 15" Pirelli P-7Rs on 8" Campys for 15 years , before a pair of 10" Campys fell into my lap. As mentioned in my 1st post, wider wheels & tires are for maximizing traction and handling. If that's not your primary goal, a narrower, taller rear tire will work fine, look OK and can even be 'adjusted' outboard a bit for better appearance with wheel shims.There's plenty of clearance for even giant rear tires with proper wheel backspace. Front tires are a completely different story.
The 285x40-15" tire was the first really wide street-type radial tire available to the public, so thats what wound up on Gr-3s with the optional 10" rear Campys. If 295-50s or 305-50s had been available, DeTomaso and the racers would have gone with those. Many Gr-3s ran gumball race tires on track or during hill climbs, or in some cases they used treaded racing rain tires because with most Gr-3 club-racers, they WERE interested in maxing traction, not necessarily in European street legality or tire longevity.
Here are some pictures with OEM tires. I have a set on my car. Yes they look wimpy especially from the rear, and they don't feel good on the road. I have decided to take mine off and go with wider tires, and just keep the OEM's as a spare. Good for originality show, but not for GO!
https://www.mecum.com/lots/CA0...72-detomaso-pantera/
Adjustable shocks so the car can be lowered would improve the looks IMO, but then you are breaking from originality again.
I wonder if anyone has tried Mickey Thompson Tires?
The Sportsman S/R are available in 26x10 (255/55) and 26x12 (305/45) in 15 inch. They even have the european E-Label on them, which make them street legal in the EU. the 26x12-15 is just 2% smaller than the 285/50-15, which is closer than the 275/55-15 Avon (3% bigger).
https://www.mickeythompsontire...-tires/sportsman-s-r
The ET Street S/S are available in a number of different sizes but look a bit sporty for the street.
https://www.mickeythompsontire...-tires/et-street-s-s
Does anyone have experience with these tires?
Pirelli has (or had) a 'Special Projects' tire building shop in Izmir (eastern Turkey) where limited market tires have been built for decades. Problem is, I understand that's also the tire shop where all the F-1 and other pro racing tires are built. Guess which takes precedence during the racing season? Nevertheless, a few such tires do trickle out- to be instantly grabbed by Euro dealers who have standing (paid-for) orders.
That's what happened up to about 2015, anyway. You need to talk to someone in the know located in Europe about today's situation. The Swedish Pantera Owners Club has gotten hold of a few dozen tires that way in the past, but the market is limited for 285-50x15 for 10" Campy rears and a few other brands of street cars. While the smaller OD 285-40 x 15s are used for Countache, Porsche & wide-body Pantera fronts; much bigger market. My info is dated- the last tires I got thru the Swedish Club was early '90s and that was a group buy with the European Lambo Owners Club. Good luck-
I was just e-mailing with Dougal (Longstone tyres) about that Pirelli 285 / 50 R 15 tyre. He said, that he has a list of people waiting for that tyre, but that list is unfortunately a very short list. He also said, that he should be meeting some Pirelli people in October and they should be discussing the production of new sizes. So maybe, if you are interested in that size, it just might be good to add your name on that list before that meeting. I have been on that list for a long time, but I doubt that my interest for one set means very much for Pirelli... dougal@longstonetyres.co.uk
Kjeld, I‘m also invested in this tire combination. The Avons are track tires, but still street legal. They have about 5mm of useful tread depth and are made with a soft compound, meaning relatively rapid wear with outstanding traction, but will also pick-up small stones and shoot them to rear of the car. Avons are used by the Cobra colleagues and you will find plenty of interesting threads in their forums. Alternatives are Pirelli P12 in 255/60/VR15 and Pirelli P6000 in 205/60/VR15.
I don't but a bunch of Shelby and Cobra guys are using them. There is a guy in LA who will actually convert them into Goodyear raised white letter tires for you. They look like vintage Goodyear race tires and perform like that also.
I've heard that about throwing stones since the compound is soft and stick to everything.
I know one 66 owner that says he gets over 10,000 miles on them but I'd expect less. I was getting about 3,500 out of W rated on my SHO.
> Reply By eugenioinnocenti: Tires for OEM 15 inch wheels On September 17, 2019 at 4:31 PM The De Tomaso Forums <alerts@hoop.la> wrote:
> == To reply by email, write above this line. == https://pantera.infopop.cc
> Hello, panteradoug:
> We're sending you this notification because you are either following the forum, the content, or the author listed below.
> New Reply To Topic
> Subject: Tires for OEM 15 inch wheels https://pantera.infopop.cc/top...499#2868468550827499
> Reply By: eugenioinnocenti https://pantera.infopop.cc/member/1598208419534361
> In: Technical Information Forums https://pantera.infopop.cc/category/1598208419742391 / Brakes - Suspension - Steering - Wheels and Tires https://pantera.infopop.cc/forum/1598208419742555
> E
> Kjeld, I‘m also invested in this tire combination. The Avon’s are track tires, but still street legal. They have about 5mm of useful tread depth and are made with a soft compound, meaning relatively rapid wear with outstanding traction, but will also pick-up small stones and shoot them to rear of the car. Avons are used by the Cobra colleagues and you will find plenty of interesting threads in their forums.
> View This Reply https://pantera.infopop.cc/top...499#2868468550827499
> To adjust your email notifications for this site, please update your notification settings https://pantera.infopop.cc/member-cp/notifications .
> To suspend ALL email notifications from this site, click here https://pantera.infopop.cc/uns...06B6CC7474A3D2BC7453 .
Kjeld, I used the Avon 215-60-15 but used 275-55-15 for the rear as they are closer to the exact measurments of the original Arriva tires. They look and fit perfect and the only issue was they are very sticky rubber which does throw up a lot of stones and debris depending on the road conditions.
Here is a link with photos of the tires on a car that I sold at RM a while ago.
https://rmsothebys.com/en/auct...era-l-by-ghia/545607
Good luck, Glenn
thanks for the input.
215-60-15 is really close to the height (- 0,16%) of the original 185-70-15.
I think 215 is right with on an 7 inch. 185 is to small.
245-60-15 also close to the height (-1,03%) of the original 215-70-15.
I think 245 is the right with on an 8 inch. 215 is to small.
The only problem is that the only match tires i can find in this dimention is AVON and they are so expensive.
Kjeld
Kjeld, I‘ve spent many hours searching for tires. The Avons are the best compromise. The cheapest I have found are at MOR in Munich. Would be interesting to seek out the number of potential buyers from the Pantera and Cobra communities for a more streetable version of the CR6ZZ tire and approach Avon with this information. If the demand (money) is there, they might just do it.
Hi
OK i have 2 important points for you.  one, i have some news for you that should help you help yourselves, and 2 i woud like your help.
  1. If you are going to be wanting to buy the wide body set up (285/40YR15 & 345/35ZR15 P7). then can i suggest doing it now. The price is going to go up. Soon. https://www.longstonetyres.co....-tomaso/pantera.html my guess is the prices will be going up in the next few weeks.
  2. This is the exciting one for a lot of you (i hope). i have heard back from Pirelli, who have said - "Dougal, we are now ready to order the 285/50-15 P7 mould and whilst checking some details regarding top speed, weight etc. all the data I found refers to the front tyre size as 285/40-15, can you refresh me as to the documentary evidence that 285/50-15 is correct ?"
I hope you guys are serious about these tyres. I am putting my reputation on the line with Pirelli. They are not convinced it is the right thing to do. I have comitted and said it will work, and put in the order needed. i will be up to it up to the eyeballs in it, as they say. My hope is that you guys will buy them.
Anyway any actual pictorial evidence (like a picture of a Pantera build sheet or sales brochure listing 285/50R15 P7) that i can send to them will be great. (308 trx window stickerOr stuff like this off a 308 Ferrari)
  • 308 trx window sticker
Epic, we're on.
After i posted on here i found this fitment guide.
Pirelli 1980Pantera 1980 Pirelli
Amusingly the chap i deal with, within Pirelli, when he was a young man, he actually compiled this fitment guide back in 1980.
Anyway I have backed that up with picture from Kimmosch, and we have the green light.
I have always said this project will take a long time, and it already has. Pirelli are on the case. i cannot garuntee any dates as yet. In fact i make a habit of not garunteeing a tyre untill i actually have it in front of me. However pirelli have been excellent in my dealings with them.
I hope i am right in saying that the people who have been buying the
https://www.longstonegomme.it/...li-cinturato-p7.html
Will back me up as to how good the quality is. The Countach Fraternity have been over the moon with them, as have the Porsche boys. I will try to keep the price as sensible as possible. However i stand by my earlier recomendation to buy P7 tyres now if you need them.
  • Pirelli 1980
  • Pantera 1980 Pirelli
